Dell E177FPf No Power
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E177FPf No Power
    Originally posted by retiredcaps
    Well, that is good news. You may have had a poor solder joint on that cap?
    Thanks for the offer, but I'll pass.
    Perhaps PlainBill can make use with just the eeprom chip from board "A"?
    Let's see, 'A' is the board with an unstable power supply. Yes, I definitely would like that board. Billy66 if you are willing to ship only the power / inverter / logic board to me, PM me and we'll make arrangements on shipping costs.
    PlainBill
    • billy66
      • Mar 2010
      • 124
      PlainBill... no problem.
      But, I do have another issue with the working monitor, that I did not notice at first. The screen is extremely blue tinted. If I bring up the OSD, it is normally colored. So, I first checked my computer with another monitor, not that. I replaced the VGA cable, not that. So I thought maybe I didn't notice the blue color at first due to it not being there... I powered down the monitor, let sit an hour to cool... and turned on and it is still blue. I just didn't notice at first. Any ideas on this one? I assume it is on the video side of the card... where to start looking? I'm half tempted to move all the power supply parts over to the other board to bring it to life... but realize that I'm learning nothing that way. Can someone point me in the right direction? And yes, I have tried to adjust the settings on the monitor...
      Thanks again for all the help.
      • seanc
        • Nov 2008
        • 1319
        You have of course done the obvious and performed a factory reset on the monitor?
        Otherwise, try DVI, assuming it has DVI. Rules out a dodgy VGA port.
        • billy66
          • Mar 2010
          • 124
          Yeah, did factory reset... same. And it is only VGA port. But good idea.
          • seanc
            • Nov 2008
            • 1319
            Do all of the colours display properly, but with a blue tint, or are you missing red?
            Bring up a colour palette in paint to confirm.
            My suggestion after, would be to try re-soldering the VGA port connections.
            A slight anecdote, I have a VGA cable on my KVM with a damaged pin, any machine connected will show up black and white when on a BIOS screen, but works fine once in an OS.
            • jetadm123
              • 2169
              #26
              Have you tried reseating the ribbon cable from the LCD panel to the circuit board. If that doesn't work, try swapping ribbon cables with monitor A.
              • billy66
                • Mar 2010
                • 124
                #27
                I tried reseating the cable... but figured it wouldn't work. The On Screen Display works. i.e. when you press menu you get the options to adjust and stuff... and it looks perfect.
                Maybe I am missing red. When I mad the background all red... it was purpleish lavender? I will try the re-soldering of the VGA port connections.
                • billy66
                  • Mar 2010
                  • 124
                  #28
                  OK, just noticed something with this issue. When I first hook up the monitor to the power cable after sitting for a bit, the color comes on normal. After about 10 seconds of being on, I can see the screen switch to the blueish color. I haven't opened it up yet to check the VGA connections... but this leads me to believe they would be good.
                  • seanc
                    • Nov 2008
                    • 1319
                    #29
                    Wiggling the VGA cable doesn't help?
                    • billy66
                      • Mar 2010
                      • 124
                      #30
                      Nah, it doesn't do anything. I checked the factory settings and the lamp has 24000 hours on it... could there be something to that? Though, I thought when the bulbs start to go or go... it is a pinkish color?
                      • seanc
                        • Nov 2008
                        • 1319
                        #31
                        Yes, things will go pink when the CCFLs are failing.
                        My re-capped 'Proview' monitor with well used CCFLs starts off very pink and gets better as it warms up.
                        • billy66
                          • Mar 2010
                          • 124
                          #32
                          OK. Mine is definitely not pink, but blue. And it doesn't get better when it warms up. Looks like I'll have to pull it apart again.
                          • billy66
                            • Mar 2010
                            • 124
                            #33
                            OK. I've decided to give up on the bluish tint monitor and try to repair board A. Here is a recap of what is and what has been done:
                            Board A... when plugged in, no LED. The transformer T850 clicks on and off... voltage at U850 pins 3 & 7 bounce all over the place (11 -16VDC).
                            Here is what I've done:
                            - Recapped entire secondary side... no changes
                            - Replaced transformer T850 from known good board (no change)
                            - Replaced I850 from known good board... did this cause I850 supplies pin 2 of U850 and wasn't getting anything out of pins 3 or 4 on I850. After swap, T850 stopped clicking. Also, U850 pins 3 and 7 now have 24.8V steady (not sure if this is high. The known good monitor had 16Vs)
                            - Decided to replace U850 from known good monitor as I found that pin 8 on U850 was only giving output of 0.25v and the known good monitor was putting out like 20v or so. This voltage goes to the gate of Q850... Q850 gate on the known good was seeing 3.58v. On the bad monitor, it was only seeing .02v... maybe not enough to turn on Q850?
                            So after swap of U850, here is where I stand:
                            Monitor wont power on. No LED, no picture, nothing. The transformer T850 clicks once or twice (sounds like it is charging up). Voltages are as follows:
                            - Filter cap: 156V
                            - U850 Pin 1- 0
                            2- 2.6V
                            3- 24.8v
                            4- 1.29v
                            5- 4.5v
                            6- 0.75v
                            7- 24.7v
                            8- 0.25v
                            - I850 pin 1- 99.4v
                            2- 98.4v
                            3- 0
                            4- 2.6v
                            - Q850 G- 0.25v
                            D- 155v
                            S- 0.008v
                            Any ideas?
                            • billy66
                              • Mar 2010
                              • 124
                              #34
                              Being this board is an "all-in-one" board with the inverter, power, and logic all on one... there is no cable between the boards... makes it hard for me to find test points. Can anyone point me in the right direction to take some measurements for the 5V, 3.3V, and 12V?
                              Also, should I start another thread for this monitor alone?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                1) D854 - dual diode should read 12V DC on middle pin ore slightly more (my guess)
                                2) 5 legged voltage regulator chip marked 1506 - look up datasheet and see what voltage should be
                                3) U801 voltage regulator
                                4) U802 voltage regulator
                                --- begin sig file ---
                                --- end sig file ---
                                • billy66
                                  • Mar 2010
                                  • 124
                                  #36
                                  1) D854 - seeing 25.4V on the middle leg.
                                  2) U851 Pin 1 - Voltage climbs very slowely from 0 to 0.882Vdc... and then stays there.
                                  2,3,4,5 all read 0V
                                  3) U801 All pins 0V
                                  4) U802 All pins 0V
                                  I haven't looked up the datasheet yet for Voltage reg, but I assume those readings to be bad.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    25.4V DC could be right for this board. If the capacitors to the right of D854 are rated for 35V, then 25.4V DC sounds right. If the caps are rated for 25V, then I believe 25.4V is too high.
                                    PS. There might be another dual diode (that is obscured by the angle of the picture - above R860). It would be facing "up" on the same heat sink as D854. If yes, that should be your 5V diode.
                                    • billy66
                                      • Mar 2010
                                      • 124
                                      #38
                                      Caps are 25V caps... And there isn't another diode on that same heat sink...
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        I missed the comment in post #33 about the 16V DC being good in the other monitor and U850 showing 24V DC.
                                        Sounds like something wrong around that area. Will have to start with post #1 and re-read as I'm definitely getting confused with all the changes made.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          Check diode D856 with your multimeter in diode check function and report the results for both diode measurements.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Akhlz001
                                            Dell Pro 13 Plus PB13250 Bios Unlock
                                            by Akhlz001
                                            Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                            09-20-2025, 07:15 PM
                                          • master3112
                                            Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                            by master3112
                                            I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                            Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                            The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
