vizio plasma
  • Tvbob
    tvbob
    • 204
    vizio plasma
    Does anyone know what cap causes the V scan to run too high (its 230v should be 207v) The adjustment has little effect. The power supply # lj44-00132a used in vizio vp50hdtv20a and sanyo dp50747. They sell a cap kit on fleabay. The set works ok with some artifacts in the pix at times.
    Its hard to see these boards now, i am trying not to have to take all the caps out of circuit to check them. Thanks
  • Tvbob
    tvbob
    • 204
    Re: vizio plasma
    Does any one know the contents of this kit? http://www.ebay.com/itm/VIZIO-Plasma...item1e65c42ea8
    • Peter9DO
      • Dec 2011
      • 277
      Re: vizio plasma
      Well, I don't know if this will help you any but I was able to find the service manual for this TV (vizio vp50hdtv20a). It has some schematics and a flow chart for trouble shooting, which always comes in handy... Hope that helped some!
      • Peter9DO
        • Dec 2011
        • 277
        Re: vizio plasma
        Sorry, I got excited and prematurely posted... here's the link:
        • Tvbob
          tvbob
          • 204
          Re: vizio plasma
          Thanks, I have that. It doesn't show the lj44-00132 power supply schematic.
          On my set, I can't adj the Va voltage (its 20 volts too high) the control pot has little effect. The tv works, but has a lot of artifacts ,sparkles . Its hard for me to see the bottom of the boards anymore.I am trying not to have to take all the electrolytic's off the board to check them.
          • retiredcaps
            • Apr 2010
            • 9271
            Re: vizio plasma
            My guess is fuses and caps based on another seller selling a kit (*cough* ripoff *cough*)
            http://www.ebay.com/itm/170781744634
            --- begin sig file ---
            --- end sig file ---
            • Peter9DO
              • Dec 2011
              • 277
              Re: vizio plasma
              Very true! None-the-less retiredcaps is the BOMB! He has helped me in some sticky situations in the past, so listen to what he is saying. By the way, never purchase any of these kits from eBay, it really is a rip off, you can find all of the items on Mouser.com very cheap. Everyone here will be willing to help, so put your wallet away! lol!
              • Tvbob
                tvbob
                • 204
                Re: vizio plasma
                Yea I going to let this post ride for a day. Maybe I will get a link for an actual schematic for the power supply (Lj44-00132). If not I will pull all the caps off and I will post the results. thanks
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Re: vizio plasma
                  Did I mention that the link I found wants $17.95 USPS Priority Mail International Flat Rate Envelope for shipping 2 fuses and 5 capacitors to Canada?
                  So $43 total?
                  • Peter9DO
                    • Dec 2011
                    • 277
                    Re: vizio plasma
                    So $43 total?
                    WOW!!!!! Is there any company in Canada that sells electronic components (like Mouser or Digi-Key here is the States)? Because that's crazy! I'm sure you're going to run into an issue anywhere you need international shipping though. I will look around to see if I can find a schematic for you for that board. By the way, who manufactures the board?
                      Re: vizio plasma
                      Check your multimeter battery. I bet it is low (causing high readings) and you have the standard sparklies/flickering pixels problem with Samsungs which is a Yrr/Yfr adjustment problem (easily fixed.) Good meters will have a battery icon show when the battery is too low.
                      • Peter9DO
                        • Dec 2011
                        • 277
                        Re: vizio plasma
                        Well, I was not able to find any schematics for the power board itself, however I came across a lot of things talking about 7812 and 7815. I know this might be a little outlandish but take a look at the 7812 to make sure it's running 12v and the 7815 for 15v the output is the 3rd pin. Here is a link to the schematics, if you would like it for reference:
                        Just a thought...
                        • Tvbob
                          tvbob
                          • 204
                          Re: vizio plasma
                          Thanks guys,I had the low bat in the DVM scenario. I have 2 wavetek DVM's This set works all secondary voltages are normal except the (vs). I can adjust the other panel voltages.The panel and sustain boards are made by samsung
                          The (vs ) potentiometer is the only control that dosen't adj Its running about 230v and should be 207v. I get a lot of artifacts with some image retention.
                            Re: vizio plasma
                            Adjusting the Vs pot, it does not vary by much? Check all the resistors around Vs potentiometer for opens/high-R and don't run the set for long, plasma panel may sustain damage, especially buffers or sustains.
                            • Tvbob
                              tvbob
                              • 204
                              Re: vizio plasma
                              Yea , I imagine the set is close to shut down mode. The sustain boards warm up very quick then get hot So I don't run it long. I will check the voltage divider circuit that the (vs) control is in series with tonight. You would think there is a schematic out there some were...
                                Re: vizio plasma
                                What's the model on the board? BN44-xxxxxx or BN94-xxxxxx? Where xxxxxx are digits, maybe followed by A,B,C etc. I may have one available.
                                • Tvbob
                                  tvbob
                                  • 204
                                  Re: vizio plasma
                                  Hey,Tom there are no bn #'s. The board # are Lj44-00132 /psdf561a01a
                                  • Chancey
                                    • Aug 2012
                                    • 25
                                    Re: vizio plasma
                                    I agree with retiredcaps...I repaired a Toshiba 42" a week ago and spent $40 when I had a feeling it was the IGBT pac that went bad. $15 for the 13pin IC...I got a fuse and an old IC for $40. I payed to learn a lesson...
                                    • Tvbob
                                      tvbob
                                      • 204
                                      Re: vizio plasma
                                      I checked the caps.and changed the ons that were out of tolerance. the problem with the high (vs) voltage was an "adjustable precision shunt regulator" in the driver circuit of the (vs) supply replaced it with an good old NTE .
                                      • Peter9DO
                                        • Dec 2011
                                        • 277
                                        Re: vizio plasma
                                        NICE! Good job TvBob!!!!! Now, what made you look at that regulator? How did you get to that as the problem?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
