Sony KDL-32L4000 Double image
  • Mr Bill
    • Nov 2011
    • 648
    The top 2" of the screen is pefrect but below that point the screen is blurry and showing a double image. I thought this would be a bad tcon board but i got a replacement from Shop Jimmy today and it didn't correct the display. Is it possible to have a faulty tcon? Can a faulty TAB do this? I would think it would be from the top of the screen to the bottom but i haven't had a tv with a loose tab yet. Twisting the screen doesn't seem to do anything and there is no slow motion or darkness.
    I am going to disassemble the panel and see if the tabs are loose. Just getting some feedback and see if i'm wasting my time. The panel is a Samsung LTY320AB01
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony KDL-32L4000 Double image
    Wow we are having the same issue. Is your panel underneath the good section jumpy and at times show a smeared image from what's on the top? Check out my thread. Mines an auria 32" with a Samsung LTA320AB02 panel. My good/bad line is 6" from the top. Everything under that is vertically jumpy and smeared.
    https://www.badcaps.net/forum/showthread.php?t=23205
    • beetle1303
      Sony KD-65X7000E - Screen double images for first few minutes then back to normal
      by beetle1303
      I have gotten this Sony KD-65X7000E TV completely dead. According to owner TV was working fine and suddenly blackout and not able to power on again.
      Checked and found D751 rectifying diode shorted, replaced and now power up and working almost normally:
      1) On power up - display double images, and flicker once every few seconds.
      2) After 3-4 minutes at this state - display suddenly back to perfectly normal (although there are few horizontal lines at the bottom of screen).
      3) Leaving on for few minutes, power off and on again will repeat the same...
      03-11-2023, 02:07 AM
    • dicky96
      HP Elitebook Screen blank - backlights but no image
      by dicky96
      Hi guys
      I'm trying to fix this laptop screen
      Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
      OK so I have the original screen which works but has lines across the bottom quarter of the screen
      I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
      04-28-2021, 07:30 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      Macbook Air M2 A2681 Kernel panics after screen replacement
      by reformatt
      Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
      It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
      07-31-2025, 08:37 PM
    • alltvrepairs
      Hisense 55AS6G screen double sided tape required
      by alltvrepairs
      I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
      I need a source for this type of double sided tape adhesive please.
      https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
      Tks!
      07-17-2025, 09:32 AM
