latitude e5550 - no charge- all battery not recognized as genuine
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    -latitude e5550 all batteries sense as non genuine(ive tried two working genuine and two new non genuine).
    -battery led flashing white and amber which indicated non genuine AC adapter. tried multiple bios.
    -ive tried multiple genuine chargers
    -the circuitry seems to be working fine and battery and charging seems to be controlled by EU2 which is ECE5048-LZY
    https://datasheet.octopart.com/ECE50...-147335658.pdf
    does this chip have to be programmed? or is it replaceable? do you all think this could be the reason?
    i have two of these same exact problem.
    tried the latest and earliest bios.
  • mon2
    • Dec 2019
    • 14713
    Re: latitude e5550 - no charge- all battery not recognized as genuine
    hi.
    1) is the ac adapter original ?
    2) measure the voltages on pins 5, 6 and 7 of the battery connector. These are used to extract the data from the battery. if the local ESD diodes are zapped, they could hinder the communication channel to the logic board. As a test, you could simply remove these ESD TVS diodes and see if the results improve.
    • sdinelli
      Sdinelli
      • Aug 2014
      • 152
      Yes all genuine dell chargers.
      dat and clk pins both fluctuate from 3.27V - 3.235V
      pres read -30mV w/o charger and flat 0 with charger
      W/O battery
      dat and clk read steady 3.305V
      pres steady 3.277V
      i assumed when battery was plugged in it pulled down pres to let it know it was there..
      PD1 and PD2 dont seem to be an issue. although im not sure what the function of them are.
      PD1 had voltage drop of .800V and 1.48V reversed
      PD2 has VD of .600mV on OL reversed
      is PD1 an issue?
      • mon2
        • Dec 2019
        • 14713
        3v2 on the SMBUS (I2C) lines is ok. These 2 lines will be used to extract ID info by the KBC controller. You may have to reflash the KBC but personally do not have experience with this area.
        The PBAT_PRES#_C line is active LOW so 0V is ok. To confirm, you can remove the battery and check the PBAT_PRES#_C line again.
        See attached. Monitor the voltage at the junction with and without the battery.
        Do you see a difference ?
        • sdinelli
          Sdinelli
          • Aug 2014
          • 152
          Yes i can confirm PBAT_PRES#_C is 3V2 w/o battery
          • mon2
            • Dec 2019
            • 14713
            At this time, believe the decision of whether it is a Dell battery or not is made by the KBC. The KBC has an internal 8051 microcontroller (if I recall correctly) that uses firmware for the assorted function. Wait for feedback from others like @SMDFlea who is very knowledgeable on the KBC. Issue may be just the incorrect bios which also holds the KBC firmware.
            • sdinelli
              Sdinelli
              • Aug 2014
              • 152
              Is that the chip i posted in first post?
              Ive tried at lest 5 bios ranging from latest to earliest.
              Thank you for your help and info so far
              • mon2
                • Dec 2019
                • 14713
                yes - same. Any chance the KBC has solder ball issues or is defective?
                Does the keyboard work ok ?
                That is, perhaps the I2C (SMBUS) lines are not reaching the KBC balls ?
                The external pull-ups are working since you have +3v3 (approx) for these open-drain lines. However, in the end, the KBC is the bus master and must communicate with the battery logic.
                I think you also noted that the AC adapter is not detected properly? That too is a function of the KBC.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Powered with ac adapter only(no battery attached)-still ac adapter "UNKNOWN"?? If yes, I think we need to fix this issue first before going to charging issue.
                  • sdinelli
                    Sdinelli
                    • Aug 2014
                    • 152
                    The adapter seems to work fine and has always been detected in bios as proper wattage.
                    The battery LED flashes white and amber only when battery is installed. both when charger is present and not
                    But i found this which only confused me more and made me question adapter circuit
                    https://www.dell.com/support/kbdoc/e...ps-and-tablets
                    The keyboard and whole laptop functions normally.
                    non of the chips seem to be BGA
                    Also i have the dead battery still.. if i put that back in the LED flashes rapid orange so it does seem like circuitry is working right and that its a weird firmware glitch
                    • sdinelli
                      Sdinelli
                      • Aug 2014
                      • 152
                      a boardview file would be nice. dells schematics suck i feel like.
                      whats up with the weird pin alpha numeric crap
                      • mon2
                        • Dec 2019
                        • 14713
                        Alphanumeric usually means the package is a BGA or QFN
                        Update:
                        Found it in the schematic and the symbol is marked as:
                        MEC5085-LZY_DQFN132_11X11
                        So it is a 11x11mm QFN (Quad Flat Pack package)
                        • sdinelli
                          Sdinelli
                          • Aug 2014
                          • 152
                          Thanks a lot. ill see what i can find now that i have the pins
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            What is the part number of the battery?
                            G5M10 or 6MT4T?
                            Become a Badcaps supporter
                            Thanks to all supporters.​
                            • sdinelli
                              Sdinelli
                              • Aug 2014
                              • 152
                              yes 6MT4T
                              i also tried the smaller sized battery. dont know P/N
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                Originally posted by sdinelli
                                yes 6MT4T
                                Bingo! That is your problem - this model work only with G5M10! 6MT4T is the same size and shape, even the connector for the battery cable is the same but is for another model (E5470). So try with G5M10 battery, and everything will be fine.
                                • dclass-pro
                                  Latitude 3301 not charge battery
                                  by dclass-pro
                                  Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                                  I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                                  I noticed 2 things:
                                  1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                                  2) if I try to turn it on without the battery...
                                  05-06-2025, 06:19 AM
                                • Carl0s-
                                  iPad 5th gen (A1823) - No charge but recognized by finder
                                  by Carl0s-
                                  Sooo - our IT got a pile of old iPads that the sales guys have been mistreating. These are free for grabs if you want to try to get one working. Thought I'd give it a try - if I get at least some life to I can give to my kid to entertain during a car rides.
                                  But the iPad it self - its a 5th gen cellular model. When I initially plug it in it was completely dead. It was not recognized by my Mac nor it started to charge. Disassembled it opened up the battery connector and checked the battery voltage. My multimeter showed 0,7v. Had a spare micro-usb charging board lying...
                                  04-15-2024, 12:51 PM
                                • orion78fr
                                  Dell Latitude E5550 LA-A911P rev 1 No Power
                                  by orion78fr
                                  I have dell laptop Latitude E5550 LA-A911P that suddenly has no power.
                                  I haven't found any short on the board (but haven't verified everything so feel free to ask), nothing is getting hot under thermal cam.
                                  +5V_ALW is present
                                  +3.3V_ALW is present
                                  +3.3V_ALW_PCH is absent
                                  +3.3V_RTC_LDO is present
                                  +3.3V_M is absent
                                  +1.05V_M is absent
                                  A_ON & PCH_ALW_ON are low on UE2 pins.
                                  PJP15 is 3.3V
                                  +3.3V_ALW_UE2 is 3.3V
                                  PCH_ALW_ON should be on no matter what when UE2 is powered right ? Does...
                                  02-22-2024, 10:06 AM
                                • BTubbs200
                                  Dell Latitude 5420: No charge, no boot; amber LED for as long as the power button is held.
                                  by BTubbs200
                                  Dell Latitude 5420 P137G
                                  Board model LA-K491P REV A01
                                  Laptop is stone dead and only reacts to the power button being held while the charger is plugged in, in which case a dim amber LED fades in and immediately fades out when I let go. Battery being plugged/unplugged does not change anything.
                                  CMOS battery was removed and reinstalled; no change.
                                  No shorts to ground have been identified on the board whilst probing the power rails in resistance mode. No visibly damaged components.
                                  No indication that the CPU is receiving power; CPU fan does not activate.
                                  Of...
                                  01-23-2025, 10:45 PM
                                • ipatch
                                  troubleshooting microsoft surface pro 4 no power no led charge light
                                  by ipatch
                                  hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                  10-05-2023, 11:59 AM
