LG 32LN5400 what is this resistor value?
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    TV was on and the owner heard a pop, the power supply 331J 1kV cap blew up and damaged the main mosfet, resistor, main fuse and the PFC controller.
    The MOSFET was an 11A 650V MOSFET, I put an 11A 600V which is the closest I have, the resistor color code was not standard, I replaced with another one from another LG PSU PFC section, it's less than 1 OHM, seems to be called rOCP.
    Now it powers up and LEDs + Mainboard works fine but with a hellish noise like coil whine, it is coming from the primary, from the transformer or the inductor, it's not bad soldering, the thing is, when powered up the voltage on main caps are 262~280V, strangely the tv works like that, this TV should have PFC, it's not boosting, the only thing different now is the rOCP and the MOSFET.
    I circled the components that were exchanged in the photos. The photo of the lone resistor is the original rCOP that went open.
  • lotas
    • Jan 2016
    • 4668
    • Russia
    Re: LG 32LN5400 what is this resistor value?
    Power schematic LGP32-13PL1
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      i once had a tv supply wining and also it was drawing high current from the mains .turned out to be bad soldering on the replaced pfc ic . tv also worked
      • lotas
        • Jan 2016
        • 4668
        • Russia
        This circuit is without PFC.
        • R_J
          • Jun 2012
          • 9558
          You need to install a proper 0.25Ω resistor, 1Ω is too large and will upset the ocp of ic101
          • lotas
            • Jan 2016
            • 4668
            • Russia
            From the photo it is already 0.05 Ohm, +/- 5%
            • Biruslapio
              • Nov 2013
              • 552
              • Brasil
              Very useful, thank you so much!
              The last black band is what caused this, it has no purpose in the resitance value or tolerance.
              I've fixed it, it was the resistor R113, supposed to be 0.25Ω, the one I wrongly replaced was 0.05 Ω, the PFC could've blown up from the overcurrent, I did a parallel association between an 0.3 and 2.2Ω, ended up with around 0.26, that was good enough, TV is fine.
              List of parts replaced:
              Q101 MDF11N65B
              C102 330pF 1kV
              R113 0.25Ω
              R106 220Ω
              F100 5A
              IC101 Sanken SSC1S311A
              I learned it's not PFC, that was a gereneric way of calling the "Multi SMPS" circuit with a mosfet.
              • R_J
                • Jun 2012
                • 9558
                The black band on the end usually means non-inductive.
                With the wrong value resistor, the ic would be operating in the wrong mode, this would result in the noise from the transformer.
                • angelos
                  • Dec 2012
                  • 571
                  • South Africa
                  Hi Biruslapio,
                  I had the 32LN5130 model blown and i had to replace all the same parts that you did.
                  The challenge was for me to find a 0.25 Ohm resistor so I combined two of them until my ESR meter gave me 0.26 Ohm, the i was satisfied.
                  The striking similarity was that we changed all the same parts. I changed the PC817 opto coupler just in case.
                  Lotas, Thank you for the diagram of the power supply it will really come in handy. Tell me how do you get the power supply diagram when the service manual does not how it. Do you have more circuit diagrams of LG?
                  • Steve2023
                    • Dec 2022
                    • 2
                    • United Kingdom
                    Hi, old thread bump but what type of resistor is this?
                    Is it a wirewound resistor or metal film resistor?
                    Does it matter if a metal film resistor is used?
                    Also is it a 2W resistor?
                    Edit ok going by that schematic file it's a wirewound resistor :-)
                    • Biruslapio
                      • Nov 2013
                      • 552
                      • Brasil
                      it was a 2W resistor, standard type? don't know the material.
                      • Steve2023
                        • Dec 2022
                        • 2
                        • United Kingdom
                        Been told it should be a fusible resistor
                        • R_J
                          • Jun 2012
                          • 9558
                          If you use a wire wound it should be a NON-Inductive type as well
                          • alfatv
                            • Sep 2020
                            • 353
                            There is always some inductance.
                            • Jane
                              How do you test MOSFET in laptops ?
                              by Jane
                              I tried to use this method:
                              Testing an N-channel MOSFET:
                              Step 1: Discharge the Gate (turn off the MOSFET)
                              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                              Step 2: Charge the Gate (turn on the MOSFET)
                              Now, place the red probe on the Gate (G) and the black probe on the
                              09-27-2024, 03:31 AM
                            • mikey5791
                              Need help to replace burned resistor in 350w atx psu
                              by mikey5791
                              Hi to all forum members,
                              Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                              The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                              Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                              Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                              12-26-2024, 04:55 AM
                            • Nooy
                              VGA MOSfet permanently shorted and loss of MOSfet pad
                              by Nooy
                              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                              02-14-2024, 02:26 AM
                            • MidnightRoller
                              Can a resistor lose resistance after hot air?
                              by MidnightRoller
                              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                              02-02-2022, 11:46 PM
                            • artvandalai
                              What resistor ohm will work better to repair this waterpik?
                              by artvandalai
                              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                              01-05-2025, 04:10 PM
