asus p4pe-x poly overhaul
+ More Options
Posts
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    had blown ost all over it.
    its going back in a hot machine shop with no a/c
    this is the 3rd board in that system.out of warrenty so time to fix it to last.
  • Newbie2
    • Sep 2005
    • 885
    Re: asus p4pe-x poly overhaul
    Are you sure it's going to work well with polymer capacitors?
    ASUS originally designed it with normal aluminum electrolytic capacitors, so the polymer capacitors may affect its operation.
    I also notice the retention mechanism is missing. If you don't know what that is, it is the black rectangular frame that the processor's heatsink clips on to.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      yes its stable in memtest and mprime.i do these all the time like that.
      and the retainer was busted due to the heat.
      i put a new one on it.
      noise/ripple on vcore and vdimm is a few mv at most now.
      • yanz
        • Nov 2004
        • 910
        what year this board made?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          iirc 2003
          • Logistics
            • Apr 2007
            • 721
            This is relevant to my interests. I have a P4PE which as of yet has not given me any problems. My 350W Antec started causing me reboots and I recapped it with Samxon's and this system has been motoring along just fine. But I've always considered giving the caps on the board attention since it's a good keeper system for me.
            Can you send me a quote for the caps I need to do mine? Thanks!
            Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
            • Wizard
              • Mar 2008
              • 2296
              Best test is prime95 torture test, this stress load the cpu and memory at same time that how I found my first recapping effort on dimesion 8300 was not effective enough. Memtest only tests the ram and that's easy on cpu and doesn't show the enough load since memory is only few watts.
              Cheers, Wizard
              • jpdoe
                • May 2007
                • 237
                But memtest has an advantage: it gives crystal clear results. I read somewhere that prime95 results are inconclusive, in the sense that sometimes it will hang on a good PC.
                So my question is: how much faith do you have on prime95 as a stability test?
                • Wizard
                  • Mar 2008
                  • 2296
                  if it hangs, them something have a problem. Can be PSU, iffy video card, even board, even capacitor choice or how it was installed, too warm CPU; chase them down. Capacitors was put in with flying thick wires, shorter than 1" but it was enough to get errors. I wanted extreme stable PC. I had it with machines that very intermittently put soft data corruptions in my stuff and intermittent crashes, having to restart software etc.
                  This what was going on with our old server. Replaced with C2D 2.2GHz, yadda yadda all the good homebuilt stuff. No corruptions in the work data.
                  And prime95 does have error reporting. If it reports any, then more work on the PC to get it stable.
                  Cheers, Wizard
                  • jpdoe
                    • May 2007
                    • 237
                    Thanks, Wizard. I'll give prime95 another try.
                    • KeriJane
                      Mac Enthusiast
                      • Sep 2008
                      • 681
                      Hello
                      I have a question for this thread.....
                      Apparently you have successfully replaced conventional electrolytic capacitors with polymer ones for use in a high-heat environment.
                      Polymer caps have different characteristics than electrolytics.
                      so.... What is a good way to determine an appropriate replacement?
                      For instance .... what would make a good replacement for a 1000uf 16v Rubycon MCZ? Is there some kind of formula or cross-reference?
                      Thank you for any help,
                      Keri
                      The More You Learn The Less You Know!
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        half capacitance is a typical replacement. you can reduce the voltage to that expected in that location on the board. like on vcore out. electrolytics are not available in less than 6.3v but polymers are available in 2.5v or 4v.
                        otherwise you just compare esr and ripple and use the polymer that provides the best specs preferably exceeding that of the caps already on the board.
                        typical polymers for vcore applications
                        chemicon PSA or PSC
                        oscon SEPC
                        lots of others
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          i used 330@16 ncc ps
                          filled the 2 empty spots.
                          i also filled the empty spots on vcore.
                          btw 2.5v is fine.
                          if you exceed 2.5v the cpu is toast!
