I am curious which idiot had to create new power connector as it is completely useless PoS in my opinion. Sice size benefit is almost non-existent over peripheral molex (and you can still use Berg which can handle lower current but is even smaller). It can withstand lower currents than standard molex even using expensive gold-plating.
Disk drives cannot rely on +3,3 V because of backward compatibilty with molex so it is not and will never be used. Not mentioning better efficieny of DC-DC module from 12 V compared to pulling +3,3 V from PSU and the fact the +3,3 V rail will one day be dropped from the ATX completely.
So the SATA is more expensive, handles less current and carries useles pin position. You cannot buy plane SATA connector anywhere because it is some proprietary PoS, compared to molex you can buy for cents everywhere. I often make different custom cabling for fans and stuff so I use molexes quite often but newer PSUs are filled with more and more SATAs and less molexes. So I need either to use splitters (and than pull hundreds of watts through couple connectors) or buy bloody expensive SATA-to-something adapters. And for example to power VGA safely you need to use 2xSATA-to-PCIe adapter because SATA can only handle 4,5 A per rail (54 watts vs. 75 watts for PCIe) where single molex can handle 11 A (so even the worst chinese crap will do at least 75 watts).
Half of the computer problems is caused by bad contacts
