Hello Guy's I have a Dell GX 620 Motherboard that has two bloated Rubycon's on it. I should mention that the system runs fine and I had it up for 24 hours without a problem.
I have a couple questions. First, are these fake Rubycon's. The five next to the motherboard are especially suspicious one of them has a black gold label and the others have black gray even though they are the same series.
Second what Caps do you recomend replacing? I will be reselling and I need a Hard drive and a OS so I don't want to spend a ton on a Recap. Also, it is running fine so. I was thinking about replacing the (4) MCZ 6.3v 2200Uf, the (5) MCZ 6.3v 1800Uf and the (1) MCZ 16v 1000uf. Should I just worry about the (4) MCZ 6.3v 2200Uf.
Thanks!
Thanks!
