Fortron Blue Storm II FSP500-60GLN
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Fortron Blue Storm II FSP500-60GLN
    well i dont really want another one which fails in 1 year so i wont be doing rma. so i am open to investigation in the name of science.
    • i4004
      • Oct 2006
      • 2029
      here's something that may be of interest....
      as said, you're probably looking at primary side as it was violent.
      • grss1982
        • Mar 2007
        • 225
        • Philippines
        @willawake: I just saw a display unit of the Silverstobe Strider ST50F here in my locality.
        It looks exactly like that Fortron unit. Same side exhaust & same exhaust near the are where the wires peak out of the unit.
        The Only difference is that the ST50F comes in a black finish instead of blue.
        CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
        GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
        Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          replaced with Corsair vx550w
          has matsushita primary and chemicon KY (although cant see secondary side i can see mercedes vent there too )
          smells really bad of paint smell though i think it will stink out the apartment when i fire this up. 5 year warranty which is pretty cool. is the smell guaranteed for that long?????
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            the smell is pvc outgassing.
            it will fade soon.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              #26
              hope so
              pvc is prohibited in eu though.......
              sick psu....i love the black powdercoat
              • gonzo0815
                • Feb 2006
                • 1600
                #27
                ...only for packaging food and the like.
                For all other purposes there are no much limits even in EU.
                • kikkoman
                  • Jul 2007
                  • 691
                  #28
                  and for construction hardware like tubes and cables, i think.
                  IIRC that was after the Düsseldorf airport almost burned down.
                  "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Heatsink size and weight doesn't mean as much as it used to.
                    If a curve (graph) is drawn for heat dissipation to current passed for any device that is PN junction based the curve isn't linear. (Transistors, MOSFETS, Diodes, Diodoe Packs, ect). The heat dissipated goes up at a faster % rate than current.
                    [I looked up a Schotkey Diode Pack to pull these numbers from.]
                    With 18 amps passing through the Diode Pack and it dissipates 9 watts.
                    At 9 amps it only dissipated 3.4 watts.
                    If you use two Diode Packs in parallel to pass the original 18 amps the total heat dissipation is 6.8 watts.
                    - Need about 25% less heatsink devoted to that 18 amps..
                    Since better PSU's are using more parallel parts to reduce heat it makes sense that better PSU's will have smaller heatsinks than one would expect based on what was typical in older designs.
                    Some of the newer better PSU's are upping the switching frequency.
                    The higher frequency means smaller transformers to pass the same amount of power.
                    I just got an FSP Epsilon FX700-GLN (700W)
                    Looks very similar to the Blue Storm II FSP500-60GLN.
                    (I wish paint on the truck was that good!)
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • i4004
                      • Oct 2006
                      • 2029
                      #30
                      willawake, was this fortron constantly on?
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        #31
                        yup 24/7 why?
                        connected to APC RS 1000
                        thanks for the article by the way
                        • i4004
                          • Oct 2006
                          • 2029
                          #32
                          i'm wondering if it was working 8hrs a day (or less) would it last 3 years?
                          hehe...
                          have some more .pdfs, will put them all in new thread, as finding thsese pdfs wasn't easy at all. i saw them mentioned, and then it was all hard google work.
                          i'll upload them here incase my fortron eats my hdds.
                          <wink>
                          still didn't dismantle it?
                          come on, let's see the autopsy!
                          • Behemot
                            • 4845
                            • CZ
                            #33
                            To not start a new thread, I will ask here. A guy changed the fan for 1300RPM Thermatake. After using it in more power demanging computer, he smelt something burning.
                            I changed the fan for one of higher airflow. Yet, when I retested and kept ir runnign for longer time, it seems that the problem is not jsut insufficient ariflow. The big input inductor next to the primary cap really is bad somehow cause it heated itself to 150 °C And it is very dark now
                            The question is, does it have some very specific values? Or can I just replace it with some other inductor I removed elsewhere? Not sure whether it is part of input filtration or the active PFC this time.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              #34
                              It is tbe active PFC coil and it is well known for getting too hot and burnt. I would replace the coil and hope that the low rpm fan was the cause of the disaster. I would also check the primary cap's esr and capacitance.
                                This is all good and well, but diodes have a negative temperature coefficient, like most semiconductors. (Excluding mosfets.)
                                As temperature goes up, this means the forward voltage drops. This causes one diode to carry more current than the other, causing its temperature to increase, which causes it to carry more current, which causes... thermal runaway.
                                This can be avoided if the resistance of the leads and PCB can effectively compensate for this and if both diodes are very closely thermally matched (i.e. tied directly to the same heatsink and ideally on either side of the sink.) Or, if the diodes are on the same die. So, you can put maybe two diode packs in parallel, but probably not many more, unless you tie resistors in series with each pack, and then your efficiency drops.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  TY! Is this only the case of Fortron's GLN, or other PSU's as well? Cause I never heard of it.
                                  Anyway, swapped for coil from my good ol' Seasonic, seems to run fien now. Will do some OCCTing
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    #37
                                    https://www.badcaps.net/forum/showthread.php?t=9660
                                    Take a look
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      Nice, thanks. I remember I have read the thread but the repair was not finished by that time, than I did not continue. Nice work. This thing looks like it is working too.
                                      Anway, I guess I will add at least ESR meter to my buying list, but later also capacitance meter and inductance meter. Could be of use:-D
                                      As for this coil of mine, I think it may even be some kind of manufacturing problem. There seem to be two spots where the wires are soldered together. I believe this should not happen. Most likely due to the heat the insulation coat broke through, than the wires got connected due to the solder and than it became even worse.
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        #39
                                        I own esr micro v4 that saved me from a lot of trouble. It measures both capacitance and esr and has survived some incidents with capacitors that were not discharged completely.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #40
                                          This one?
                                            Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:50 AM
                                            Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
