Enermax EG365P-VE
  • i4004
    • Oct 2006
    • 2029
    Enermax EG365P-VE
    with pce-tur and pce-tul caps this psu is grossly overpriced for the quality of the components.
    nevertheless it served me well for over 6 years(and is still in working order), probably because 2 fan design, which in itself is silly today: why not just put one bigger fan?
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Enermax EG365P-VE
    If this Enermax is overpriced, then LC Power ones are a real theft: they cost roughly the same (35-40 euro, about $50-55) while employing lower grade components.
    Zandrax
    Have an happy life.
    • i4004
      • Oct 2006
      • 2029
      i payed 100€ for it back in the 2001. in that time i don't think 350was bottom of the barrel. paradoxically higher wattage came later. pcs now consume much more power (yes, they're many times more powerfull, but still..).
      my philosophy is different nowdays: i'll rather buy few fortrons and keep an eye on them (swap them every 6months or every year and thoroughly inspect one that was taken out).
      something is rather annoying when it comes to psus old and new: why are they not putting dc regulation ics that would prevent overvoltage from appearing on output?
      because regulators for such big currents don't exist or are too expensive(?).
      i would really like to see some sort of added safety on output, not just relying on pwm ic. anybody knows of something that could be used there but not movs(?), as they don't last long and are usually made for too high voltages.
      perhaps something along these lines
      http://focus.ti.com/docs/prod/folder...t/tps2400.html
      http://www.linear.com/pc/productDeta...2,C1029,P38400
      even as a standalone device that attaches to output connectors(prior ot them being plugged into mobo) it would be nice.
      with such device you could even be safe with crappiest chinese psus...hehe...
      • gonzo0815
        • Feb 2006
        • 1600
        LC-Powwr sells very cheap here, 550w for 35€ is very different from Enermax, starting at 50€.
        An Corsair VX420 will cost about 60€ adn a Seasonic S12 330 goes for 50€.
        This sets the price / quality point at the moment.
        Any way, i think the silly dual fan design, which releases the vast amount of the hot air back into the tower, is what left the PCE-tur capacitors to survive that long.
        But the problem with this is the bad case ventilation and therefore higher ambient temperature and thus more noise.
        I have recapped two of the older designs, one went back into operation, the other will still shut down under heavy load (e.g. a skt. A system with Athlon Xp ).
        For older 3.3v and 5v based systems, the EG365FMA is still a very good psu, apart from the silly cooling solution and the capacitors.
        I modded my recapped EG365FMA with a 120mm fan and case from a death POS PSU, and now it is a very nice working horse.
        • gonzo0815
          • Feb 2006
          • 1600
          Linear voltage regulator are to inefficient at the usual power levels in ATX PSU`s.
          If a PSU goes foo.bar it does generate a over voltage.
          I think som Transil diodes are the easiest way to go, and i think they are reliable.
          Put a fairly high ampere fuse in series and your device e.g. your HDD is safe, as long as the mainboard shorts out the interface over voltage.
          But this would not prevent a death system due to high ripple. Another way is the crowbar circuit, wich does simply the same thing but it can be set for a current limit.
          • i4004
            • Oct 2006
            • 2029
            5v stby section is not easilly visible in above images, so here it is
            http://picasaweb.google.hr/i4004b3/E...55vStbySection
            it's 2 transistor design with feedback via optocoupler.
            not as good as tinyswitch designs, but not as bad as self oscillating crap in mobo destroyers...
            also some valuable black enermax goo there(on that big white resistor and blue cap), it seems..huh...
            i think i'll put this psu back in service, instead of chieftec that's eating backups
            https://www.badcaps.net/forum/showthread.php?t=5628
            let's see can it do few more years...
            • gonzo0815
              • Feb 2006
              • 1600
              My EG365FMA already has a tiny switcher, but the VE`s are certainly the older design.
              Any way, from what i know, the design must be solid & save, at least i haven`t heard about burned up boards by Enermax PSU`s.
              • i4004
                • Oct 2006
                • 2029
                psu power connector has 4 pins less than one on mobo so it won't be used after all.
                • g1150
                  Hardware Devel
                  • Feb 2013
                  • 8
                  • germany
                  Hi folks,
                  I know this is an old thread, however...
                  I just have the exact same PSU in my hands (eg465-VE).
                  Symptom: turn on, very short power surge on mains....quite. no 5v standby. no DC 300V, fuse OK.
                  just wonder,...has anybody a schematic of eg465 ?
                  thanks!
                  • g1150
                    Hardware Devel
                    • Feb 2013
                    • 8
                    • germany
                    need eg465 schematic please
                      Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
                      by momaka
                      Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
                      First shown is the label below, so anyone reading can see what PSU we're dealing with here.
                      02-15-2021, 01:05 AM
                    • eigma
                      Enermax Tomahawk ETK450AWT PSU Repair
                      by eigma
                      A few weeks ago my computer power supply (Enermax Tomahawk ETK450AWT) stopped working. Of course this led me down a reverse engineering and circuit debugging rabbit hole ;-) I also learned about capacitor Equivalent series resistance along the way, and wrote an article about it all. Here are some sneak peeks:
                      And the full article:
                      https://github.com/cpatulea/src/blob...awt-psu-repair
                      Enjoy!...
                      01-18-2021, 09:14 PM
                    • LeKowalsky
                      Enermax Platimax EPM1500EGT random turn on
                      by LeKowalsky
                      I'm novice in smps repairs and lurker here also in addition to my preparation I have read Jestine Yong's Troubleshooting & Repairing Switch Mode Power Supplies many times and I cautiously proceeded in small steps a time.
                      What's on the table?
                      Enermax Platimax 1500W (EPM1500EGT)
                      Symptom
                      A fault is a little tricky here. When plugged into the wall for a first time (i.e. after proper discharge) PSU starts on power button (PS_ON) as expected, runs smoothly with all the voltages in tolerance also shows quite stable operation...
                      04-14-2020, 08:05 AM
                    • Xorat
                      Enermax MODU 87+ EMG500AWT
                      by Xorat
                      Hello there,
                      i got this power supply from Enermax, that was Dead until i removed that one cap. It is connected to 12 V and ground and it was completly shorting. Now my question would be, do i need to replace it and if, how do i get the value of it ?
                      Without the cap it turns on and runs just fine (stress tested for about 2 h with mainboard, cpu and gpu).
                      best regards...
                      06-16-2021, 06:38 AM
                    • Dan81
                      Wolf in sheep's clothing - Enermax in a Deer casing
                      by Dan81
                      As the title says, I got a "AO" (no, not AOpen , their units are FSP) PSU that sits doing nothing and I have a complete PCB from a Enermax EG-365P/VE sitting here. It's a "P4 ready" variant according to the old casing. (which I ditched because of way too much rust)
                      Here are my goals with them:
                      - remove whatever PCB the Deer has (and probably reuse it when I need a solid 200/250 watt unit for say a Pentium MMX - Pentium 3 range machine)
                      - remove the auxiliary AT- style plug from the Enermax and the -5v rail as well since they have no...
                      04-10-2018, 03:52 AM
