DELL INSPIRON DUO: No power, 17volts on power switch.
  • siddiq
    • Dec 2011
    • 121
    • Ghana
    Hi everyone, Dell inspiron Duo PIM00 LA-6471P.19v only on power connector and 17v on power switch. No 3.3v or 5v.I do not have schematic so it is very difficult trying to trace power lines. Any help will be appreciated.
  • siddiq
    • Dec 2011
    • 121
    • Ghana
    Re: DELL INSPIRON DUO: No power, 17volts on power switch.
    Well it turned out that upon closer scrutiny, PD22 was missing [don't know how] and PU10 and PQ18 was shorted so laptop works fine now and power switch voltage gracefully dropped to 3.2v. :mrgreen:
    • JPComputers
      • 1
      • usa
      Hi Siddiq. Would you remember how you fixed the short. I seem to have the same problem with a laptop my friend brought me. Thanks. [IMG][/IMG]
      • LimesKey
        Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
        by LimesKey
        Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
        10-17-2025, 05:33 PM
      • Powderfanupnorf
        Dell AL440LX power on switch circuit help required
        by Powderfanupnorf
        Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
        So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
        My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
        06-24-2024, 01:24 PM
      • zlr8r
        Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
        by zlr8r
        hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
        Ill try and give as much info as I can.
        Dell Inspiron 17 (7786) Laptop
        Service Tag: 5J0NHT2
        Bios: 1.9.0
        When I received this , it would only flicker on the KB backlight for a second, then off and on.
        Then it started getting weirder!
        Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
        12-12-2023, 09:31 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Tomylee
        Dell Inspiron 15 3511 – Won’t power on after plugging in, one chip gets extremely hot
        by Tomylee
        Hi everyone,
        I have a Dell Inspiron 15 3511 that stopped turning on after my friend plugged in the power adapter.
        Here’s what I’ve checked so far:
        No reaction when pressing the power button (no LEDs, no fan).
        The power adapter works fine (tested).
        One chip gets extremely hot as soon as I plug in the charger.
        The capacitors around that area are not shorted.
        I’m attaching photos of the board to show the issue.
        Based on this, what kind of fault or defective component could be related to this overheating?...
        10-19-2025, 12:24 PM
