Dell 5161-7DS power supply - how to turn on using paper clip?
  • retiredcaps
    • Apr 2010
    • 9271
    A friend handed me 4 Dell GX280 all with bloated Rubycon caps near the CPU. I haven't opened up the power supplies, but they are 5161-7DS (20 pin).
    According to diagram DC Power Connector P1 (about halfway down the page)
    http://support.dell.com/support/edoc...g/pwrsply0.htm
    pin 14 is PS_ON and pin 9 is 5V FP.
    Normally, for an ATX power supply, I use a paper clip and short PS_ON to GND and the power supply turns on. From the diagram, this looks like an ATX power supply and all the pins correspond to an ATX power supply.
    I can't do this for the 5161-7DS for some reason. I took a working 5161-7DS and tried shorting PS_ON to GND and got nothing. I tried adding a load (SATA hard drive) and still nothing.
    Q1) What am I missing?
    Q2) What does "FP" stand for in the 5V FP documentation?
    --- begin sig file ---
    --- end sig file ---
  • selldoor
    Slow Learner
    • 7870
    Re: Dell 5161-7DS power supply - how to turn on using paper clip?
    Q1 - Pass
    Q2 FLEA POWER ------- no I didnt think youd believe me!
    http://answers.google.com/answers/th...id/185999.html
    • selldoor
      Slow Learner
      • 7870
      Well I have given it time for for someone to be brave enough to suggest this but in the absence of any takers.
      Have you got the power switched on
      Is the correct lead plugged in
      Is the fuse in the plug OK
      Have you tested the lead in something else.
      Have you tried a different lead.
      • retiredcaps
        • Apr 2010
        • 9271
        Hmm, another Dell unconvention.
        And yes, I would not have believed you without the references. Thanks.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Perhaps these PSU are more like LCD monitor PSUs? (i.e. you pull the PS-ON high to turn on the PSU).
          Try pulling PS-ON up from 5V FP through a 100 Ohm resistor.
          • retiredcaps
            • Apr 2010
            • 9271
            Sorry, somehow missed your post. I was probably distracted by the flea power post?? Suggestions are always welcome. I sometimes overlook the obvious.
            1) There is no power switch at the back.
            2) Not sure what you mean by lead, but I have done this many many times and I know I have the correct color (green for PS_ON).
            3) The power supply work if it is connected to the motherboard and all output voltages are correct so the fuse is working fine.
            There must be something else with these power supplies and causes them to turn on.
            • retiredcaps
              • Apr 2010
              • 9271
              When plugged into the AC outlet the 5V FP and PS_ON (on all 4 of them) measures 5.00V.
              PS_ON is pulled low to 0.00V when jumpered with ground.
              I don't have any resistors at the moment so I will have to break out the soldering iron and get one from a junk power supply.
              I tried jumping all 4 and none of them startup. However, if they are connected to the motherboard, they all start. Looks like I will have to probe all the pins and use min/max to figure out what is going on.
              • selldoor
                Slow Learner
                • 7870
                Could it be something to do with Power OK signals Grey cable pin8
                See https://www.badcaps.net/forum/showth...?t=4793&page=2
                post 36 - Not sure why that came into thet thread but it might help.
                If Pcbonez hadnt vanished he may have been able to advise.
                • PeteS in CA
                  • Aug 2005
                  • 3579
                  • USA, Unsure of Planet
                  If the P/S has a UC384X type PWM controller, there's often a high value resistor and electrolytic cap (probably with a zener across it) that provide start-up bias. have you checked to see if the resistor is open, the zener shorted or the cap has worn out (high ESR)? That cap is one of the "little caps you should replace but might forget."
                  PeteS in CA
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Selldoor earns a well deserved this time around. His link to PCBONEZ's PWR_OK thread led me in the right direction.
                    For some reason, PWR_OK wasn't getting pulled up to 5V on this model. So I jumped 5V FP to PWR_OK in addition to PS_ON to GND. So with both jumpers in place, the 5161-7DS turns on. 3 out of the 4 power up, and of course the one that doesn't work is in the case with non bloated Panasonic caps by the CPU.
                    Now onto taking the covers off and seeing how dirty and how many number of bloated caps.
                    On all other ATX power supplies that I have at home including name and cheap brands require only jumping the PS_ON to GND.
                    PS. The reason I use the paper clip method for standalone power up is because when I get computers for repair, I don't want to fry the motherboard in case the power supply's 5V standby rail has failed high. One of my friend's Antec measured 11V DC on the standby rail and fried his motherboard.
                    PPS. Note to selldoor, time to change slow learner to Badcaps Veteran.
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • CMCM
                      Russound CA4 Power Supply Repair
                      by CMCM
                      Hello Everybody,
                      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                      The outputs marked 12v and 20v are all measuring only 1v.
                      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                      The capacitors physically look clean (no bludgesor leaks) and...
                      07-03-2025, 01:12 PM
