Power suply doesn't work (DPS-214CP)
    Re: Power suply doesn't work (DPS-214CP)
    Can you verify that the OPTO PC901 is OK?
    The Brown out protection IC 902 can be left out for now, the output of that IC will go low if the AC brown out is detected.
    I believe the SMPS IC is in the open loop protection mode.
    • NoN4me
      • Jun 2017
      • 20
      • Spain
      Yes, at least it's not shorted. But when I arrive home I could desolder it and make a circuit to check it's behaviour
      In case of a faulty OPTO souldn't the drain pin starts swiching and stops suddenly after a little bit time?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        Like budm, for me IC901 is in latched off / over voltage / shorted winding protection mode or the replacement PWM is bad again. Then it will do the ramping up down triangle thingy then too.
        • NoN4me
          • Jun 2017
          • 20
          • Spain
          Ok, I have checked the OPTO, it works OK.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            Can you make a list on which components you have tested so far?
            • NoN4me
              • Jun 2017
              • 20
              • Spain
              #26
              At first I supoussed that there was an issue in primary so I cheked every compoment surrounding DDA010 (resistors capacitors diodes an even the transistor) then I checked there wasn't no shorts at secondary that can stop DDA010 from switching. After that I replaced DDA010, but nothing changed and then I came here and I followed al your recomendations.
              • NoN4me
                • Jun 2017
                • 20
                • Spain
                #27
                So, to sumarize, I have cheked: D901, D903, D902, Q901(not shorted), ZD901, ZD902 and ZD906 (not shorted), ZD903 (behaviour checked), PC901, D950, R905, R915, R914, R902, R901.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8340
                  what about the transformer itself, R903 and C905?
                  • NoN4me
                    • Jun 2017
                    • 20
                    • Spain
                    #29
                    R903 is ok, C905 replaced and nothing changed.
                    The transformer values are:
                    Pins 7-5: 0.8 Ohm
                    Pins 9-10: 0.5 ohm
                    Pins 1,2 - 3,4: 0.1 Ohm
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8340
                      what disturbs me is that the PWM isn't even trying to switch on the Drain pin. Maybe verify this again. Because if it isn't at all, I think that the PWM is bad, even tough you put a new one in.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        I am not good with spec sheets but it looks to me that 5v on feedback will shut down DDA010
                        • NoN4me
                          • Jun 2017
                          • 20
                          • Spain
                          #32
                          Hello again, good news, or maybe not. Y have checked again, and as I said when I plug in the power supply I can't see nothing in the scope related to the Drain pin... but I really have 5 volts in +5V in the secondary side for arround half a second.
                          I'm still confused, I hope this new info helps.
                          Thank you one more time for all the help and the advice given up until now.
                            May I ask how you go about testing that OPTO IC?
                            • NoN4me
                              • Jun 2017
                              • 20
                              • Spain
                              #34
                              Already done, as I said in #22 and #24 I checked and it works ok.
                              Apart fron the fact that it was not shorted I made a external circuit to test it with good results.
                                Well the reason I ask you because it is obvious that SMPS IC did go active for seconds to produce output on the cold side even though you indicate there is no reaction on the Drain pin of the IC so may be the scope was not set to trigger properly to catch action on the Drain pin, I just want to make sure we get correct data, that's all.
                                • NoN4me
                                  • Jun 2017
                                  • 20
                                  • Spain
                                  #36
                                  Yes, probably I made a mistake with the scope. The IC produce output fir a little time but then it stops and doesn't work.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8340
                                    What happens if you take L951 out in the secondary and measure the 5V rail directly at the legs of C951A (3300uf 10V), while plugging the PSU in? I am trying to find where the other end of 5V' goes (right after L951)?
                                    • NoN4me
                                      • Jun 2017
                                      • 20
                                      • Spain
                                      #38
                                      Exactly the same, I have 5 volts as I plug it but afterwards the voltage decreases I guess that's because of the capacitors.
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8340
                                        ??? The capacitors shouldn't have an effect on that, unless there have a high ESR value. Maybe post some high resolution pictures of your PSU, front and back.
                                        • Lanparty
                                          • Oct 2012
                                          • 8
                                          • Bulgaria
                                          #40
                                          Hello guys I have the same problem but with Delta smps on Grundig ...Ic DDA010 and IN1M101 ...I saw this post and I have to say that all of my elements are ok even I have changed both IC'S but still the same symptoms ..I have two questions to you do you have pulsing on Vcc pin on Ic DDA010 ??
                                          Did you check the capacitor 22pF 1Kv and diodes which are connected to the primary coil of your transformer ?
                                          My st by is only 3,6 V ...You have to tray to diskconnect the jumper between both ic's Vcc jumper then if the tv works and goes into loop IN1M101 is defective ... I have attached a file that may help you finding the problem ...
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
