Help with Motor Control Board - ProForm treadmill
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Help with Motor Control Board
    if both of those diodes read 0 both ways then they are both shorted. as toasty stated in post 13 you should check those 2 diodes dz1 and dz4 and budm stated in post 7. i'm not the best troubleshooter but i would bet those 2 diodes are part of the problem if not the complete problem just from looking at the burn marks on the board. you said they read 0. is that with the leads of the dmm reversed also? if so you would have to desolder a leg and retest to make sure. if they do read 0 both ways they are both shorted.
      If we can get good clear pictures of the top and bottom side of the board, that will help troubleshooting a lot.
      • Crrose
        • Dec 2013
        • 165
        • Usa
        The 2 diodes start with a reading but immediately go down to zero on. That is with the leads reversed also. Here is a top and bottom view of the board. The mounting plate and heat sink had to be removed for the photos. I also checked the black/white/red wires that are supposed to read 5v but they fall well below that at around 3v.
        • Crrose
          • Dec 2013
          • 165
          • Usa
          Any idea what size these to diodes are? All I can see on DZ1 is 5Ph and on DZ4 24-C838.
            They may be 5V and 24V, but best way to test is to lift one leg off the board to get better reading.
            Can you the numbers on Q4 and the one next to it?
            I will look at the board layout using your pictures, I may ask for more close up pictures later on.
            • Crrose
              • Dec 2013
              • 165
              • Usa
              #26
              Ok Q4 has ST Morocco 9540 427654 W33N20 on it and the smaller D4 has 98-39 U1520 on it.
              • Toasty
                • Jul 2007
                • 4171
                #27
                As I said about 10 posts ago...
                veritas odium parit
                • Crrose
                  • Dec 2013
                  • 165
                  • Usa
                  #28
                  Ok I changed DMM's because the other was acting to erratic. When I test the 2 zenner diodes now DZ1 reads 005 and DZ4 reads 007. The registers the same with the leads reversed also.
                  • Crrose
                    • Dec 2013
                    • 165
                    • Usa
                    #29
                    I just tested D4 and Q4. When I place the black lead to the left leg and red to the right I get a reading of 414 and if I reverse the leads there is nothing.
                    On Q4 black to 1st leg and red to middle, nothing. Black to 1st and red to 3rd I get .094.
                    Black to 2nd leg and red to 3rd I get .521.
                    Red to 1st and black to 2nd I get .611.
                    Red to 1st and black to 3rd I get .112.
                    If that helps at all.
                      Did you lift one leg off the board?
                      Also check them using Ohm mode.
                      • Crrose
                        • Dec 2013
                        • 165
                        • Usa
                        #31
                        That was with them still attached to board. I'll try my hand at desoldering.
                        • Crrose
                          • Dec 2013
                          • 165
                          • Usa
                          #32
                          Removed one leg of diodes from board and when set at 200ohm I get .6 on DZ1 and 1.4 on DZ4. If it is set to diode mode I get .001 and .002 with continuity.
                            "I get .6 on DZ1 and 1.4 on DZ4"
                            They are bad.
                            • Crrose
                              • Dec 2013
                              • 165
                              • Usa
                              #34
                              So I need a 24v and a 5v. Are they all the same except for the voltages?
                                So this the virtual PCBA I come up with, hard to trace out double-sided PCB.
                                The motor is driven by the power MOSFET.
                                One of the black power resistor is for soft-start, another one is for Voltage drop for the Zener diode.
                                  With the diodes removed, you can see the whole numbers as printed to verify the Voltages. They look like 1W ZENER.
                                  • Crrose
                                    • Dec 2013
                                    • 165
                                    • Usa
                                    #37
                                    The black one broke in half when I tried to remove it from the board (after I got the reading) that was the 24v one. Can I go up in wattage if I can't find a 24v 1w?
                                    • Crrose
                                      • Dec 2013
                                      • 165
                                      • Usa
                                      #38
                                      DZ1 says C15PH
                                        That will be 15V Zener, if the legs will fit the holes then I would go with higher Wattage.
                                        I would also mount them with body above the board like 0.100"~0.250" to allow better air flow.
                                          • 31260
                                          5w is good, next one down is 1.3w
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Yanleb
                                            LG 60PK550 Logic Control Board EBR63450301
                                            by Yanleb
                                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                            C57: 3.30V
                                            C61:...
                                            07-20-2023, 12:38 AM
                                          • cyclones
                                            Motor control board repair
                                            by cyclones
                                            I have a motor control board I am trying to repair. I've been told the motor is fine, but the control board will only make the motor go one direction but not the other. Power comes in through a linear transformer and then a rectifier bridge and then filter caps. No schematics for the board. Relays on the board are 24V so I started by setting my bench PSU to 24V and injecting voltage. There are several LEDs. All but one LED lights up. There are test points labelled +15V, 0V and -15V. When checking voltage potential between +15V and 0V, I get a perfect 15V. For -15V to 0V, my meter shows approximately...
                                            10-30-2021, 10:39 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
