Asus VW192S, no power from psu.
  • senndogg
    • Dec 2011
    • 383
    • Albania
    hello.
    i have an Asus display, model VW192D with no 5V and 12V power. psu model is Delta EADP-45AF.
    the monitor has been serviced elsewhere before but i have no info what has been done it. i can see some caps changed and the ccfl transformer removed, but this is another issue.
    tested so far:
    in the secondary circuit:
    fuses: ok
    rectifiers: no one shorted.
    in the primary:
    main rectifier: ok
    main DC current: around 330V
    diodes: no one is shorted.
    resistors: all seem good.
    Q101: not shorted
    voltages of C101:
    except pin 2: 4.8V, all other pins show 0 voltage in respect to the (-) minus from the rectifier.
    i have found a repair manual of a similar display which has this psu too, but no info about voltages was given.
    any idea is appreciated. thank you.
    Re: Asus VW192S, no power from psu.
    With monitor unplugged, can you check resistance across the small cap on the primary side (not the 400V one.) If it reads very low, it could be a bad controller IC.
    • senndogg
      • Dec 2011
      • 383
      • Albania
      there are 2 small caps in the primary side.
      the first one:
      is in the 4.8V rail close to the IC.
      reads: TAICON 50V 6.8uF.
      measures 6.9uF (measured with Uni-T UT61E in caps mode)
      the resistance in the circuit with the cap removed is over 330k ohms.
      the socond one:
      is in a rail across the legs of the voltage transformer.
      reads: Ltec 50V 47uF.
      measures 49uF.
      the resistance in the circuit with the cap removed is over 7M ohms.
      note: the voltage across this cap when the monitor is plugged is 0V.
      • senndogg
        • Dec 2011
        • 383
        • Albania
        sorry, 2 my faults.
        in the first post i meant pin 2. which is the Vcc of the IC.
        and the resistance with the cap C105 removed, that means the resistance between the Vcc and the (-) is 52k Ohms.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          "ccfl transformer removed, but this is another issue. "
          Is it another issue? or is there a protection circuit so that if there is nothing on the inverter primary, the system will shut down the voltage to that section.
          • Behemot
            • 4845
            • CZ
            I may get this display for (hopefully) good price, with white screen. Any hint? I suspect signal board or TCon and that's not what I could repair just like the power board…so not really sure if I should proceed this one.
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • abajor
              Asus G634j Rog Strix SCAR Power rail shorted nothing hot on thermal camera.
              by abajor
              I haven't been able to find a schematic or board view for one of these out in the wild. I had one come in with a no charge/no boot issue.
              It Uses two pairs of Source to Source Mosfets after the power jack to prevent back flow from battery or PSU after the power jack.
              The drain on the board feed side of the Mosfets measures a near dead short to ground. I attempted a voltage injection there it draws about 1.4A at 1V absolutely nothing heats up on the thermal camera.
              It draws 1.86A injecting directly to ground.
              Is this just the way it is when these ultra...
              03-19-2025, 03:23 AM
            • OOF DIO
              ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
              by OOF DIO
              (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
              (Had 3 problems, now just 1)
              I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
              I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
              I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
              04-19-2025, 05:03 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
