Guys i need Bios Dump + EC for Toshiba C55-A-1NE ( PT10S ) Part No : PSCGJE-00T00CS4. If anyone have please share the schematic also. It is giving headache to me. It came without power i repaired it and it works very well. after few hours it won't work properly. Now switch on, no fan, no power button LED only battery LED and front power indicator LED working.
Toshiba C55-A-1NE ( PT10S ) Bios dump
Re: Toshiba C55-A-1NE ( PT10S ) Bios dump
I've managed to extract the bios update from toshiba, got 2 pieces bin files.
1@pcs ME_FW bin
1@pcs Uefi image bin
The size ME_FW a litte few than 2mb. Flashing with your Prog, Probably it fullfilled automatically.
Uefi image contains ITE firmware at the Beginning of file.
Look the contents with HxD apps, Compare these file with yours. Only at Beginning file and End of file, if look similar then you can flash with those.
You must backup your dump first.
Make sure you have signal PLT_RST at pin 22 wifi connector and DDR3_DRAMRST# at pin 30 Slot RAM
Good luck
PS: Maybe you will got issue to extract it. Since Im using 7z 64 bit versionAttached Filesif you find these attachements useful please consider making a small donation to the site
Thanks for your suggestion meritosari. I will do it and give you the updates.I've managed to extract the bios update from toshiba, got 2 pieces bin files.
1@pcs ME_FW bin
Good luck
PS: Maybe you will got issue to extract it. Since Im using 7z 64 bit versionComment
Before is OK signal was good.
After definitely bad I think.
Probably wasn't bios issue.
I always trust Firmware/Bios from Official update IMO
ME_FW in Pegatron always make me confuse.
ME FW store in 2 MB chip separately from uefi image. On others mobo we always find the EC bios in smaller chips of mb (size2 mb).
But Pegatron do that opposite the thing.
May be wait for another good dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi meritosari,
I found the problem. The problem is on RTD2132R chip. I replaced it from another spare board. I used your UEFI Bios dump and i used old ME_FW dump on it. Now the laptop working. Thanks for your help.Comment
Great!.
I'll make a note "LOG SERVICE" from this case. May be tomorrow have face problem like this.Comment
hi raajkumar,Guys i need Bios Dump + EC for Toshiba C55-A-1NE ( PT10S ) Part No : PSCGJE-00T00CS4. If anyone have please share the schematic also. It is giving headache to me. It came without power i repaired it and it works very well. after few hours it won't work properly. Now switch on, no fan, no power button LED only battery LED and front power indicator LED working.
I have same problem. switch on, no fan, no power button LED only battery LED and front power indicator LED working.
Can you give advice on what should I do?Comment
by AhariHi all,
I...-
Channel: BIOS & Schematic Requests!
by mkdjDear all,
I have a ASUS ZenBook UX480F with the following symptoms:
I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
Troubleshooting Attempts:
Channel: Troubleshooting Computer Displays
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by DProf.High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
Toshiba Dynabook T55/AB, PT55ABP-BJA2
MODEL NAME. Satellite L50-D series
P[ART NO PS57MN-00600R
Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....-
09-26-2024, 04:30 AM -
- Loading...
- No more items.
