Guys i need Bios Dump + EC for Toshiba C55-A-1NE ( PT10S ) Part No : PSCGJE-00T00CS4. If anyone have please share the schematic also. It is giving headache to me. It came without power i repaired it and it works very well. after few hours it won't work properly. Now switch on, no fan, no power button LED only battery LED and front power indicator LED working.
Toshiba C55-A-1NE ( PT10S ) Bios dump
Re: Toshiba C55-A-1NE ( PT10S ) Bios dump
I've managed to extract the bios update from toshiba, got 2 pieces bin files.
1@pcs ME_FW bin
1@pcs Uefi image bin
The size ME_FW a litte few than 2mb. Flashing with your Prog, Probably it fullfilled automatically.
Uefi image contains ITE firmware at the Beginning of file.
Look the contents with HxD apps, Compare these file with yours. Only at Beginning file and End of file, if look similar then you can flash with those.
You must backup your dump first.
Make sure you have signal PLT_RST at pin 22 wifi connector and DDR3_DRAMRST# at pin 30 Slot RAM
Good luck
PS: Maybe you will got issue to extract it. Since Im using 7z 64 bit versionLast edited by meritosari; 05-06-2017, 11:25 AM.Comment
1@pcs ME_FW bin
Good luck
PS: Maybe you will got issue to extract it. Since Im using 7z 64 bit versionComment
Before is OK signal was good.
After definitely bad I think.
Probably wasn't bios issue.
I always trust Firmware/Bios from Official update IMO
ME FW store in 2 MB chip separately from uefi image. On others mobo we always find the EC bios in smaller chips of mb (size2 mb).
But Pegatron do that opposite the thing.
May be wait for another good dumpAttached FilesComment
Hi meritosari,
I found the problem. The problem is on RTD2132R chip. I replaced it from another spare board. I used your UEFI Bios dump and i used old ME_FW dump on it. Now the laptop working. Thanks for your help.Comment
Great!.
I'll make a note "LOG SERVICE" from this case. May be tomorrow have face problem like this.Comment
I have same problem. switch on, no fan, no power button LED only battery LED and front power indicator LED working.
Can you give advice on what should I do?Comment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
Channel: BIOS Requests ONLY!
by DProf.High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
Toshiba Dynabook T55/AB, PT55ABP-BJA2
MODEL NAME. Satellite L50-D series
P[ART NO PS57MN-00600R
Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....-
09-26-2024, 04:30 AM -
by CityminHi all,
S/N : 5RNK9FFT70...-
by Ziome3eknhHello, I need to fix the BIOS dump or some other working one
Model: Toshiba Dynabook Satellite pro C5-E-104
SN: 70014063A
Motherboard: IP3_KN16R_MB_V20_200326A
Platform intel Core i5 8gen
Attached dump...-
04-24-2025, 11:35 AM -
- Loading...
