Hi! I have a P6T Deluxe motherboard from Asus that does not power on at all. I tried to short the power on pins on the motherboard with a jumper and also tried the included power switch and neither of them does anything.
However, if I short the green and black wires from the ATX connector the motherboard powers up normally and even boots Windows 7.
I measured that the voltage between the PWR and ground pin is 3.3V when the motherboard is off and PSU connected.
Do you have any idea what is wrong with the motherboard or which components should I try to replace?
Pictures of the motherboard attached.
I'm sure many others will find this info helpful too.
