P52 Bios 20m9 Need
  • black0hackers
    • Jul 2020
    • 367
    P52 Bios 20m9 Need
    Some one have P52 Type 20M9-000LUS can share me please!
    My org bios turn on but not coming display!
  • ScorpioMan86
    • Dec 2016
    • 94
    • South Africa
    Re: P52 Bios Need
    What is your board model number ?
    • peste
      • Dec 2016
      • 13562
      • ROMANIA
      Re: P52 Bios Need
      try..
      • black0hackers
        • Jul 2020
        • 367
        Re: P52 Bios Need
        Originally posted by peste
        try..
        thank you for your help!
        it power on and still no display.
        sound beep playing
        i used Lenovo PC Diagnostic check and get info like picture attach
        • siwykk
          • May 2020
          • 55
          • N/A
          Re: P52 Bios Need
          sound beep playing
          Try this one.
          • black0hackers
            • Jul 2020
            • 367
            Re: P52 Bios Need
            Originally posted by siwykk
            Try this one.
            Thank you so much!
            • Clarify4082
              • Oct 2022
              • 67
              Lenovo P52 BIOS
              I need P52 BIOS please.
              Model: 20M9
              Serial: PF-1FR56Y
              Bootloop with the orignial...
              Backup bios attached
              • hoaca388
                Badcaps
                • Jan 2022
                • 12322
                Re: Lenovo P52 BIOS
                Model: 20M9
                Serial: PF-1FR56Y
                P52 (Type 20M9, 20MA) Laptop (ThinkPad) - Type 20M9
                • Clarify4082
                  • Oct 2022
                  • 67
                  Re: P52 Bios 20m9 Need
                  Not working, power LED lights up, power button blink 3 times. No fans, no beeps, nothing
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12322
                    Find hardware causes.
                    • Clarify4082
                      • Oct 2022
                      • 67
                      Tried to change RAM etc. nothing worked. With the old bios the fans are spinning and I get beep codes if RAM is missing. So I think there is no hardware issue!?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12322
                        Sorry to tell you that this problem is not caused by the bios.
                        • Clarify4082
                          • Oct 2022
                          • 67
                          Re: Lenovo P52 not powering up
                          I´ve flashed again the version attached. I´ve got it from this forum, but don´t remember the exact post, I´ll try to figure it out.
                          With this BIOS, the Laptop is starting. I get no HDMI output, but I get the error code 0288 for Display Error, wich is fine, because there is no internal display attached.
                          Also I get 4 short beeps.
                          The system starts directly when I plug the charger. No blinking on power led. Power off and power on again works with the power button.
                          Fans are spinning and the system stays on.
                          I think the hardware is fine, otherwise the laptop wouldn´t start?
                          I´ve checked the bios with ME Analyzer, it says:
                          Note: This CSE ME firmware was not found at the database, please report it! (See attachements)
                          Any ideas on this?
                          • Clarify4082
                            • Oct 2022
                            • 67
                            Hello again ,
                            checked everything hardware related, I think it´s not a hardware issue. (See: https://www.badcaps.net/forum/showth...&highlight=P52)
                            I´ve tried to extract a fresh bios from the original Lenovo file to flash this, but Innoextractor don´t give me a .exe or .cap file.
                            Can you extract a fresh bios from the original installer (attached)?
                            thanks!
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12322
                              Hello again ,
                              thanks!
                              Here
                              • Clarify4082
                                • Oct 2022
                                • 67
                                Thank you!!
                                Finally the spare LCD-Screen arrived and I got the laptop working with the bios attached (working_20230919).
                                There is one thing that needs to be fixed.
                                With the running bios (working_20231909), everything works fine but it takes 30 seconds to get to the Lenovo boot image.
                                So I think this is because of a bad/missing/wrong ME.
                                But if I patch a bios you provided with a new/cleaned ME the Laptop don´t power on.
                                If I try to clean the ME on (working_20230919) I get an Error in the intel flash image tool (see attachments).
                                Can you please have a look again?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12322
                                  Thank you!!
                                  File's corrupted
                                  • Clarify4082
                                    • Oct 2022
                                    • 67
                                    Sorry, next try.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12322
                                      Sorry, next try.
                                      Here you are
                                      • Clarify4082
                                        • Oct 2022
                                        • 67
                                        Thank you very much!
                                        Everything works now
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • ngngocson113
                                          I need bios asus tp301u ( uma ( vga share))
                                          by ngngocson113
                                          hi everyone
                                          i need bios asus tp301uj ( "uma " vga share)
                                          my mainboard doesn't use vga chip and it uses vga together with cpu.
                                          I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
                                          thanks everyone....
                                          09-25-2025, 02:20 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
