ASUS N752VX power signal missing ?
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Asus N752VX
    The notebook, after I replaced the pch, and seems to start up correctly but I have a doubt, staying on the bios screen I checked some voltages and the VccGT power signal (Processor Graphics)
    it is at 0 volts, I suppose it is the power supply of the video card integrated in the CPU chip. In the power sequence I see this signal as the last step and it should be enabled.
    What I did not understand?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: ASUS N752VX power signal missing ?
    iGPU power rail may not be enabled when iGPU is idling or when dGPU is being used instead.
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      So dGPU is used by default and iGPU with operating system, but usually those repairs guide are amde by manufacture ?
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • reessi
        HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
        by reessi
        I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
        It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
        What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
        I have checked these lines in diode mode and they seam normal -> 600.
        I have checked to see if they come on for even a fraction of a second...
        07-15-2025, 09:14 AM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
