LG 60PB660V Plasma tv Help Please
  • raybla
    • Jul 2012
    • 10
    • United Kingdom
    connected to the mains red led on - press remote for set to come on led goes out
    on the power board con that goes to Zsus
    VS= 210 volts
    VA = 56 volts
    M5V = 5 volts
    On Zusu board con p132 18 volts is only 4 volts removing the lead to ysus makes no difference
    Is my zusu faulty
    thanks for any help in advance
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 60PB660V Plasma tv Help Please
    What symptoms are you seeing on the screen? What is the Vsc voltage on the Y-Sus Bd. If you disconnect the connector P132 does the 4V rise to 18V?
    • raybla
      • Jul 2012
      • 10
      • United Kingdom
      Thank you for getting back to me - there is no sign of life on the screen at all Vs voltage at P130 Y-Sus board is 204 volts - disconnecting P132 at the Z-Sus makes no change stays at 4 volts
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Did you try a Logic Bd. test? To tst the Logic Bd. That is the little Bd in the center, look for two holes called 'EXT AUTO GEN'. Disconnect the cable that comes from the Main Bd. Insert a piece of wire to bridge the two holes. Plug in the TV and turn it ON. If you see the test patterns running then the Main Bd. is faulty. If no test patterns show then another board is defective.
        BUT BEFORE DOING THAT look on the Y-Sus Bd for two resistors labeled Vsc, the RED DMM probe is places on the +ve and BLACK DMM probe on the -ve and another test point -Vy. Do these voltages match what is on the label????
        • raybla
          • Jul 2012
          • 10
          • United Kingdom
          hi no need info how to do this please
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Didn't quite catch your grammar, there. What do you mean?
            • raybla
              • Jul 2012
              • 10
              • United Kingdom
              Hi Andrew sorry I have not been very well and was unable to continue this repair until now - I am looking for the resistors you mention on the Y-sus board however I cannot locate them I am attaching a picture of my board
              thanks Ray
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                -Vy is measured across R254 (+) RED probe and GR170 (-) BLK probe and you could measure Vsc with RED probe on pin3 or 4 and BLK probe on chassis GND.
                • raybla
                  • Jul 2012
                  • 10
                  • United Kingdom
                  volts across r254 = 2 volts
                  volts from r254 to gr170 = 0 volts
                  volts at pins 3 & 4 vsc = 2.5volts
                  I have not linked the pins on the small board yet
                  • livo
                    • Dec 2017
                    • 9
                    • United Kingdom
                    Did anyone find i fix for this issue?
                    • thuss
                      • Jul 2012
                      • 317
                      • uk
                      Hi sorry about hijacking this thread, I got the same problem as the op but on the ysus board I get 0 voltage on the VY. on the Z sus the vzb voltage is 73.
                      ( It doesnt have the resistors VSC).
                      All the voltages are there i.e 205/Vs and the 55/Va
                      I inserted a wire at EXT AUTO GEn and it did not generate any test patterns so main board is ok.
                      But as the op I get 4 volts when there should be 18v output from the zsus.
                      On the Ysus board there is no voltage going to the buffers.
                      I have checked the Y sus board and I cant find anything wrong with it.
                      I'm going to check the Zsus tomorrow
                      • raybla
                        • Jul 2012
                        • 10
                        • United Kingdom
                        Hi thuss - did you solve this tv repair - I had Ysus and both buffer boards repaired / checked by professional repair guy still no go with this tv missing is the 18volts on the Zsus panel - tried EXT AUTO GEN still no screen main panel and power supply also replaced - I dont want to bin this tv now as spent quite a bit on it so far - many thanks Ray
                        • thuss
                          • Jul 2012
                          • 317
                          • uk
                          sorry no- still working through it.
                          • raybla
                            • Jul 2012
                            • 10
                            • United Kingdom
                            Hi thanks hope you can fix it still trying to repair mine going to look for a Ysus panel now
                            • Pat P.
                              • Mar 2019
                              • 5
                              There's a few threads with LG panels, have a look at them - they all seem to have similar problems, mostly with the Ysus not supplying the 18v to the Zsus. The issue seems to be centered in the power supply section of the ysus board.
                              • chrismurphy
                                • May 2014
                                • 251
                                • australia
                                faulty buffer boards
                                • Amrehab
                                  • Jul 2019
                                  • 11
                                  • United Kingdom
                                  I have a problem with my 48 in Samsung Plasma TV (images attached).
                                  When I was watching my TV a month ago, I heard a very small explosion after-which the screen turned black so I have turned the TV off. After 5 minutes I turned it back on to find that I have an image but it is washed out and pixelated. I kept it on for a while and then I turned it off for about two weeks. Afterwards, I turned it back on to find out that the screen has two or three large black patches which will slowly recede to reveal the washed out pixelated image. I believe the black patches are only shown when the TV has been cool for a while.
                                  Any idea how can I solve this problem? I need some expert help please!
                                  Thank you in advance and sorry for posting on an existing thread.
                                  Best Regards,
                                  Amr
                                  • raybla
                                    • Jul 2012
                                    • 10
                                    • United Kingdom
                                    Hi Pat P & Chrismurphy thanks for your input, This is what I found on the Ysus panel Q552/Q553 shorted R559 o/c replaced with the correct parts
                                    C873 on top buffer board blown not sure what value is here had another board handy - tv now repaired many thanks all
                                    • raybla
                                      • Jul 2012
                                      • 10
                                      • United Kingdom
                                      Thank you
                                      • tvtimmy
                                        • Mar 2015
                                        • 1160
                                        • usa
                                        Thanks for the update, good job!
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Hi everyone,
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                          MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                                          by sam_sam_sam
                                          I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                                          I open it up to find non brands name capacitors in it
                                          I am not sure how this switching power supply is set up
                                          Could someone please explain how this power supply works
                                          Here is the capacitor ESR results
                                          (1) 47uf@50 volts 0.46
                                          (2) 47uf@50 volts 0.45
                                          New 47uf@50 volts 0.35
                                          (1) 100uf@25 volts 0.34
                                          (2) 100uf@25 volts 0.35
                                          New 120uf@50 volts 0.08
                                          (1) 220@25 volts 0.13...
                                          10-21-2018, 10:02 AM
                                        • Truncatedhose
                                          Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                          by Truncatedhose
                                          Greetings all!
                                          Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                          Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                          07-04-2018, 10:59 AM
                                          I am looking for a transformer secondary of 60 volts @ 30 amp
                                          by sam_sam_sam
                                          The primary voltage is 480 single phase the second voltage needed is 60 volts
                                          Now it could be 30 volts 0 volts 30 volts preferred
                                          Or it could be 60 volts 0 volts 60 volts and just use one side of
                                          Output amp need to be at least 30
                                          Dose anyone know where I can find one
                                          This is what is the device I am working on
                                          The problem with this one is that it is over heating and smelling like it is over heating
                                          When it has a load on it...
                                          07-01-2020, 08:14 PM
