Sanyo 32648 (DP26648) Repair Description
  • Ed Hall
    • Sep 2014
    • 30
    I see it's requested that repairs be documented as well as troubleshooting, so this is one I recently repaired without asking questions here:
    Note: I added DP26648 to the title because the User's Manual does and leads me to the thought that maybe both sets use the same boards. If this is not the case, sorry to have misdirected any readers.
    The trouble manifested as a red LED for about three seconds, then nothing, for three attempts. Then, nothing further until the set was unplugged, at which time I could get three more tries.
    Voltage checks showed 5VDC, but no 12VDC or 24VDC at the appropriate connectors (CN902 & CN903). There was 163.5VDC across the main capacitor (C800). With each power on attempt (for three attempts), PSON showed 5.01VDC for about three seconds.
    There are two MOSFETs (Q601 & Q602) connected somewhat in parallel with C800. Q601 measured 161.0VDC at the drain, 0.0VDC at the Gate and 10.7VDC at the Source during the three second window. Q602 read 1.2VDC at the Gate, 10.7VDC at the Drain and 0.0VDC at the Source during the three second window. I had trouble measuring the MOSFETs in circuit with the diode setting on my meter, so I removed them for testing. They were both FQP16N25C types, but I got different readings comparing them out of circuit, so I ordered and installed two new ones. BTW, readings of the new ones were different from both of the originals, but, of course, matched each other fairly closely.
    With the new ones installed, the set appears to be functioning normally.
  • Ed Hall
    • Sep 2014
    • 30
    Re: Sanyo DP32648 (DP26648) Repair Description
    Just noticed (too late for edit) that I omitted the DP prefix for the model in the previous post, so I added it to this one so searches could work better...
    • cj_reha
      Mystery 80s Sanyo cap - perhaps polymer?
      by cj_reha
      Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
      01-06-2023, 09:24 AM
    • uvoll
      ADBMS6815 full datasheet or SPI register description
      by uvoll
      I'm asking this for a friend, he has a backup battery, a quite large unit, that does not
      work as intended. Even the service techican was not able to solve all problems so far.
      My friend tried to log the SPI bus, but there is a lot of communication going on.
      Without any meaningful description on the Ic's internal registers he's quite lost.
      The datasheet that's avalible for download form Analog Devices is only 2 pages and contains
      nothing more than a block diagram and a coarse description of the operation.
      11-20-2023, 09:48 AM
    • toddw65
      Sanyo DP5834 - Gray Screen
      by toddw65
      Hey All,
      I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
      Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
      Thanks,...
      10-31-2024, 10:37 AM
    • hugocarmo
      Sanyo VHR-D4710G VCR no sound.
      by hugocarmo
      Hi again guys.
      Today I have a problem with this Sanyo VCR.
      I bought it online, It worked sometimes.
      I recap the Power supply and it started working fine.
      Image is perfect and all digital effects too.
      All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
      I have no sound on playback, on tuner, or aux in.
      On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
      On one of the sound processing...
      01-23-2024, 12:58 PM
    • m4a2t0t
      50's Sanyo monitor
      by m4a2t0t
      What type of caps can I use to replace these Rubycon (K) caps? Can I use a film cap? I cant find any aluminum electrolytic caps that go that low. They are .033 uf and .047 uf
      06-16-2025, 07:04 PM
