hp 450 g3 it will not start
  • poweron
    • May 2019
    • 371
    • italy
    main: DAX63CMB6C0 REV: C
    with this notebook something a little strange happens when I connect the power supply connector, the relative LED of the connector lights up and at the same time also the LED on the on / off button for three seconds then turns off while the other stays on, if I try to press the button on / off does not turn on, I measured on the button pins and I measure 2.4v (usually 3.2v), which go to ground by pressing the button, +3 and +5 voltages are present, what tests can I do? can it be a corrupt bios problem?
    thank you
    • 21040
    Re: hp 450 g3 it will not start
    check voltages on PU3 ,all pins, post your results. The power button needs +3V_ALW. Also check voltage on CN5 with and without the ribbon cable attached
    • poweron
      • May 2019
      • 371
      • italy
      I can't find PU3, nothing is printed on the card, only the model
        • 21040
        Look for the Quanta X63 boardview,it here on the forum and available on the net on free schematic sites.
        • poweron
          • May 2019
          • 371
          • italy
          measurements on CN5 both with and without flat:
          pin1 = 3.5v
          pin2 = 3.5v
          pin3 = 2.4v
          pin4 = 0
          measurements on PU3:
          pin1 = 3.4v
          pin2 = 3.4v
          pin3 = 0.6v
          pin4 = 3.5v
          pin5 = 3.5v
          pin6 = 7v
          pin7 = 4.7v
          pin8 = 19v
          pin9 = 0
          pin10 = 3.5v
          • poweron
            • May 2019
            • 371
            • italy
            measurement on Q8:
            pin1 = 3.3v
            pin2 = 2.4v
            pin3 = 3.5v
            pressing on / off button pins 2 and 3 go to 0v
              • 21040
              Can you remove C28 and check if the voltage goes up,if it does replace the cap.If the cap is ok Test Q8 again,i think you got the pins mixed up.
              • poweron
                • May 2019
                • 371
                • italy
                the C28 is ok, but there is something that does not fit me, according to the dataschit the pins of Q8 should be as on the diagram but on the board it is on pin 2 that I measure the 2.4v while according to the diagram I should measure them on pin 1, and when I press the on / off botton it is pin 2 that goes to gnd and pin 3 goes to 0v, llego photo of q8
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  I think the pin which you have markes as pin3, should be pin1.
                    • 21040
                    The 2N7002K gate is pin 1. The schematic pins are wrong .
                    • poweron
                      • May 2019
                      • 371
                      • italy
                      as you can see in the photo the number of pins corresponds to that found on the datashits, therefore: pin 1 = gate pin 2 = source pin3 = drain, but what I would like to know when I turn on the notebook goes to gnd pin 2 source, also because pin2 of Q8 and pin 3 of CN5 are connected together. to reset the micro-ec that is to turn on the notebook, pin 73 of the micro should go to 0v right? only it is already at 0v
                      • poweron
                        • May 2019
                        • 371
                        • italy
                        replaced Q8 but does not turn on yet, voltage on pin 2 is now 2.5v
                        also I noticed that Q6 and Q7 are not mounted
                        • ionut68
                          • Sep 2020
                          • 8
                          • Romania
                          Hello
                          I have a Model X63C PCB with the same problem as "poweron"
                          How was the problem solved?
                          Poweron with what software did you open "Quanta x63C-MB_C.bdv?
                          • corrize
                            Where to find a very small fpc connector 0.3mm between 2 pins ?
                            by corrize
                            Hello, I search this connector (oxydated).
                            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                            Do you know how to find this connector please ? What is the exact name for find it ?
                            08-06-2024, 05:25 PM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • Tomylee
                            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                            by Tomylee
                            Hi everyone,
                            Sorry for the person who’s going to read all this !
                            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                            07-11-2025, 11:52 AM
                          • araxnido
                            Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                            by araxnido
                            Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                            When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                            06-10-2025, 09:26 PM
                          • TimeRabbit07
                            Asus FX517ZC charges but power button does nothing
                            by TimeRabbit07
                            Hi all!
                            I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
                            Here are its various numbers and identifiers:
                            Model short: FX517Z
                            Model long: FX517ZC-HN114W
                            SN: NANRCX01S57842E
                            CN: 3SDB 12M
                            MFD: 2022-10
                            Motherboard model: DA0NJLMBAE0 REV E
                            Symptoms:
                            The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
                            History so far:
                            The...
                            09-04-2024, 05:48 PM
