New problem with E151FPp
  • Nama
    • May 2009
    • 127
    I have repaired 3 of these with help from the forums. But this last one has a problem I have not ran into with any other monitor.
    The CCFL's light and LCD displays an image.
    Here is the problem. It looks like a strobe light flashing very fast.
    I have tried unplugging each CCFL and each one still strobes.
    Any idea's?. Thanks in advance. Jacob
    ^Learning to walk on rice paper without leaving a trace,
  • Nama
    • May 2009
    • 127
    Re: New problem with E151FPp
    Never mind I'm not going to fool with this board. I forgot I had another one with a cracked LCD. I just swapped boards and fired it up.
    I have many boards that I can't find posts about on bad caps. Most I have been able to repair with knowledge gained from other posts.
    Would it be a good idea to take detailed pictures of each board I repair and start a thread called. "Board archive" or something to that effect?. It may not be needed but sometimes I would like to know what a board looks like before I open up the monitor. Just a though. Jacob
    • Nama
      • May 2009
      • 127
      OK... never mind my previous never mind.
      I have to many monitors in my workshop. I got confused on what LCD I posted about.
      Problem still persists..
      Flickers, or strobes constantly. But still shows a picture and never shuts off.
      The grasshopper has much to learn Master!
      • Bobdee
        • Jun 2008
        • 461
        Havent seen this one myself, but as I know you can put your hands on other inverters to swap, (that at least would eliminate Inverter)
        They use 2 inverters in this model
        Delta dac 12b062
        Ambit T501028.00
        Also COMPAQ tft 5015, model pe1212 use these inverters (and poss other Compaq's)
        This may help
        • Nama
          • May 2009
          • 127
          I will keep on the lookout for one, Very good idea, Do you think it would be OK to use a totally different inverter to check the back lights?. Or would this not be what I'm looking for. Are you saying to swap inverters to test the main board?. Or to test CCFL'S. Thanks Bobdee, Jacob
          • Bobdee
            • Jun 2008
            • 461
            Not so, try a swap on inverter to see if problem goes away, if it does inverter is problem
            As you have unpluged CCFLs one at a time and problem stays then I doubt that its your CCFLs
            as for swapping any inverter I would wait for Equevarae he the one for that, if you can find one of the ones I sugested earlier then they will do
            if inverter same when swapped then power supply needs looking at
            • Bobdee
              • Jun 2008
              • 461
              Thinking on the above, if top pair was unpluged and was the same,
              and you done same with bottom pair then that should eliminate Inverter and CCFLs
              (not my day)
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • SDNarcia
                Dell 15R-5521 keyboard problem (KBC?)
                by SDNarcia
                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                As additional information,...
                07-20-2024, 10:47 PM
