Samsung UN50EH5300FXZA No Picture
  • SHADOW3277
    • Jun 2014
    • 123
    Picked this up cheap and trying to get it fixed. It turns on and there is no picture but I can see the menu with a flashlight.
    Voltages on power supply at CNM803
    pin 1 12.56v pin 2 3.44v
    pin 3 12.56v pin 4 12.56v
    pin 5 12.56v pin 6 3v
    pin 7 12.56v pin 8 0v
    pin 9 0v pin 10 0v
    pin 11 5.35v pin 12 5.35v
    pin 13 5.35v pin 14 3.44v
    There are 2 test point for LED,s that I get 0 volts. I also get 0 volts across the connector pins LU802
    There are 3 regulators on the Mainboard. All are labeled LD1117AG
    I get voltages on them as follows:
    0 3.3 5.1
    0 1.7 5.1
    .2 1.5 3.3
    I have unplugged the mainboard from the PS to see if that would trigger the backlights as I've done before on other Samsung models and there was no change. I also unplugged the TCON and there was no change. Any help on how to proceed next is appreciated.
  • thoma
    • Sep 2012
    • 268
    Re: Samsung UN50EH5300FXZA No Picture
    ftp://helpedia.com/pub/temp/datashee...itors/Samsung/
    ftp://helpedia.com/pub/temp/datashee...t_track_guide_[SM].pdf
      At this point you are having the problem with the power supply-LED driver board becuase the backlights should be on and sttay on when the cable between the power supply and the main board is disconnected.
      BTW, next time please put the pin names after the pin number so it will be easier for us to know right away as to what signals or Voltages are missing.
      So more likely to be bad LEDs problem, but we need to check the DCV on the LED connector first. The LED connector has pin names for the pin so take the reading of those pins.
      Samsung BN44-00668A Power Supply / LED Board
      http://www.shopjimmy.com/samsung-bn4...ed-board-1.htm
      The LEDs are connected in series so if one goes open circuit or high resistance then you will not have backlights.
      Pictures provided by shopjimmy.
      • thoma
        • Sep 2012
        • 268
        What about BLU on_off Backlight on off
        and Power on_off
        • johnboy1313
          • Nov 2012
          • 1959
          You could have failed LEDs as well. I fixed a UN50EF5000FXZA recently that had several failed LEDs. Same fault. The previous owner had purchased a new PSU hoping that it would fix the issue with no luck.
            Hi thoma:
            They are OK.
            Pin 14 (PS-ON) 3.44V
            Pin 6 (BLU-ON) 3.00V
            • SHADOW3277
              • Jun 2014
              • 123
              For the LED connector:
              Pin 1 D+ 335v
              Pin 2 D+ 335v
              Pin 3 S1- 1v
              Pin 4 S2+ 1v
              Pin 5 NC 1v
              Pin 6 S2- 7v
              Pin 7 S3+ 7v
              Pin 8 D- 7v
              Pin 9 D- 7v
                The boosted VLED (335VDC) is OK, you have open circuit or open LED in the LED string.
                http://www.shopjimmy.com/samsung-de5...s-8-strips.htm
                • SHADOW3277
                  • Jun 2014
                  • 123
                  Those strips at SJ don't match my panel# but I do see some on ebay for sale I'll give a shot.
                  Thanks for the help budm and everyone.
                    It can be due to the bad connection at the board terminals so you may want to check them out first.
                    • thoma
                      • Sep 2012
                      • 268
                      @budm would it be possible to post
                      the DCV on the LED connector when the LCD-TV is repaired?!
                      This would help for orientation a lot of technicians!It should be no problem
                      to measure after repair and post it!!!
                      regards thoma!!
                        There is chart printed on the board for the Output Voltage of the LED connector, it shows as 229VDC 470mA (it may not be true for this TV since same blank board may be stuffed with difference parts for difference Voltage requirement), that should be the running Voltage with loads, but we will find out when the OP fixed the problem and take the reading after the repair is done.
                        • thoma
                          • Sep 2012
                          • 268
                          Thank you budm!
                          I can see if I read your threads that you are absolute profi!
                          You know what you are talking about!!
                          Very good!!!!
                          regards Thoma!
                            Originally posted by thoma
                            Thank you budm!
                            Very good!!!!
                            regards Thoma!
                            Thanks for all those links to the service manual, especially the one for the SAMSUNGs.
                            • thoma
                              • Sep 2012
                              • 268
                              No Problem!Budm!
                              ftp://helpedia.com/pub/temp/datasheets/monitors/
                              more schematics from other producers!
                              regards thoma!
                                09-07-2024, 05:50 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • Dodgethis
                                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                by Dodgethis
                                Hello all,
                                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                09-11-2024, 07:39 AM
