Samsung LE32A437 + BN44-00213A
  • GodG
    • Aug 2012
    • 16
    • Portugal
    HI,
    i got this tv some time ago.
    I saw 2 post regarding this power supply, but neither of them solved my probem .
    the Symptoms are:
    When tv is on standby (red light steady on);
    I press power button and it starts to blink red light 5 times;
    Then enters on standby again without turning on.
    Reading the posts found on this forum decided to "retouched " a bunch of solders, hoping that the problem was a dry solder joint - no luck.
    Unfortunatly doing that QM801 got dead, RM813 blew up, DM804 open, DZM805 and DZM806 dead , and fuse blown off course.
    Replaced all of them including QM802.
    Now when i connect the tv the red light goes on. But when i press the power button i start to ear a noise, after two or three blinks of the red light. Somethink like when u connect a small call with wrong polatiry similar to a squeeze noise and decide to disconnect the unit from the mains.
    As a last resource i removed CM809 and CM808 but ended up with a blown fuse.
    ps: i have also removed all the glue from all the caps.
    Could someone please help me?
    thanks in advance.
  • sordids999
    • May 2013
    • 2155
    • uk
    Re: Samsung LE32A437 + BN44-00213A
    posting clear pictures of the boards of your tv may help you more with fixing your problem
    • GodG
      • Aug 2012
      • 16
      • Portugal
      sorry, i was thinking that schematic was the important thing. my bad.
      thanks
      • GodG
        • Aug 2012
        • 16
        • Portugal
        anyone has a clue about this situation?
        thanks
        • GodG
          • Aug 2012
          • 16
          • Portugal
          please someone?
          • GodG
            • Aug 2012
            • 16
            • Portugal
            no one has anything that can help me?
            thanks for the time
            • sordids999
              • May 2013
              • 2155
              • uk
              Have u checked voltages from psu ?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8212
                Why is it that QM801 blew and took everything out underneath QM802, jet leaving everything alone underneath QM801? What am I missing? The noise you are talking about is coming from where and sounds like what?
                Maybe use the light bulb trick in series with the AC input and try again. Also a variac would come handy in this case.
                  "Reading the posts found on this forum decided to "retouched " a bunch of solders, hoping that the problem was a dry solder joint - no luck.
                  Replaced all of them including QM802." That sounds like solder bridges something was not done right, those parts will be damaged if the Drain is shorted to Gate.
                  I would inspect the board closely, check and see if you do have boosted PFC Voltage (>360VDC). I would leave Q801, 802 out for now.
                    09-07-2024, 05:50 AM
                  • Kaar3l
                    Samsung QLED QE65Q7FNAT only standby light
                    by Kaar3l
                    TV: Samsung QLED QE65Q7FNAT
                    PSU: BN4400940A
                    MB: BN94-12832K
                    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                    09-24-2024, 01:35 PM
                  • marcinq
                    Samsung UE60KS7000 No Standby Light
                    by marcinq
                    I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                    I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                    05-26-2025, 11:36 AM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
                  • DXseekerMO
                    Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                    by DXseekerMO
                    Hello everyone!
                    Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                    Symptoms:
                    1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                    2) TV does not appear to turn on
                    3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                    4) "Power on" terminal on Power Supply has 3.26v
                    5) "A13V" terminals have 12.9v
                    6) Stand-by test jumper on Power Supply has 12.9V
                    7) Optical audio jack on Main Board illuminates
                    8) With stand-by...
                    06-09-2021, 12:19 AM
