Samsung 2493 HM issue
  • zulururu
    • Aug 2011
    • 43
    I Just discovered that forum a couple days ago and there seems to be very knowledgeable people and a lots of information here !
    I have a Samsung syncmaster 2493HM which was working fine until a few days ago, then suddenly the backlight started to go dim and a few seconds later, the monitor was black.
    Now, when I turn on the monitor, the blue LED light comes on and stays on solid, never go to sleep (never amber or blinking) and the screen remains blank. Even with a flashlight I don't see any walpaper.
    I looked at some similar post in the forum and didn't find any solution yet. I am very new at this.
    I didn't find any obvious damaged caps, the fuses seems to be good, I checked the 2 voltage regulators on the logic board as per this thread
    https://www.badcaps.net/forum/showth...ghlight=2493hmand I find the same results as Werthles:
    "On the red circled chip i got 5.22, 0, 5.22 on the three pins starting from the top in the image. On the yellow circled chip i got 2.52, 0, 3.31 on the three pins starting from the top in the image."
    Attached are pics from my different boards.
    Can somebody help me please ??
  • alexanna
    • Mar 2010
    • 1346
    Re: Samsung 2493 HM issue
    I do see 2 Caps that looked bulged.
    On the left side of the power supply there is a connector, I can read that some pin are 24Volts,There should be some pins labeled on/off or p/on and one that is marked dim,and some grounds.
    With a signal going to the monitor what voltages do you read on these pins?
    • zulururu
      • Aug 2011
      • 43
      Hi Alexanna,
      Thanks for your quick reply, on the left hand side connector there are pins labelled +24v, Gnd, SOS, BL, A_DIM.
      Do I have to plug all the cards together to measure these voltages ?
      • alexanna
        • Mar 2010
        • 1346
        It would be best to have everything connected,Please be careful not to short anything to ground.
        • zulururu
          • Aug 2011
          • 43
          I have:
          +24v:1.2v
          Gnd: 0v
          SOS:0.13v
          BL:0.13v
          Adim:0.06v
          • alexanna
            • Mar 2010
            • 1346
            Whats the number of th power supply BNxxxxxxx?
            • zulururu
              • Aug 2011
              • 43
              I am working tonight, so I don't have the board in front of me but according to the picture it's BN44-00195A.
              Thank you very much for your time !!!
              • zulururu
                • Aug 2011
                • 43
                Apparently this Power supply is also used on the samsung 245BW and 245B...
                http://cgi.ebay.com/Samsung-2493HM-2...-/170619669136
                • alexanna
                  • Mar 2010
                  • 1346
                  That's what I thought.
                  There are 3 threads open on this P/S now.
                  On the connector going to the logic board, there should be a p/s on and a 5.3v. Pins
                  I don't know for sure if 24v is on that connector but if it is measure it.
                  What voltages do you measure?
                  Do the 2 capacitors near that connector appear domed to you?
                  • zulururu
                    • Aug 2011
                    • 43
                    Should I leave the logic board unplug for the measurement ? I will check that tomorrow and let you know...
                    As I recall the 2 caps top seems flat view from the side.
                    Thanks again !
                    • alexanna
                      • Mar 2010
                      • 1346
                      Thanks again !
                      Every thing hooked up
                      • zulururu
                        • Aug 2011
                        • 43
                        Here is the measurements I did on the connectors going to the logic board:
                        With the monitor switched ON/Switched Off:
                        24v Det: 0.12v/0.01v
                        pwm dim: 0.06v/0v
                        Brt_ctl:0.06v/0v
                        A_dim:0.13v/0v
                        Bl_en:0.11v/0v
                        NC:0v/0v
                        NC:0v/0v
                        5.3v:0.26v/0v
                        5.3v:0.26v/0v
                        GND:0/0v
                        GND:0/0v
                        GND:0/0v
                        +18v:0v/0v
                        +18v:0v/0v
                        +18v:0/0v
                        GND:0v/0v
                        GND:0v/0v
                        GND:0v/0v
                        +5v Micom: 5.21v/5.21v
                        Power EN:3.22v/0v
                        • alexanna
                          • Mar 2010
                          • 1346
                          The Power EN 3.2V is missing,that is what will request the 5.3V and 24 V. to turn on
                          at this point I am not sure why its missing
                          • dumpystig
                            • Jul 2011
                            • 485
                            Hmm... that board really is dead
                            System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                            • zulururu
                              • Aug 2011
                              • 43
                              Well, I have 3.2v on the Power en when the monitor in turned On, and 0v on the power EN when the monitor is turned off.
                              Maybe my last post is not really clear:
                              Power EN:3.22v/0v means monitor On:3.22v, monitor Off:0v
                              • alexanna
                                • Mar 2010
                                • 1346
                                Thats a good thing,There is another thread tats describes you problem with some more things to test.If you can't find it i will try to add a link
                                https://www.badcaps.net/forum/showthread.php?t=15796
                                • zulururu
                                  • Aug 2011
                                  • 43
                                  Thanks for the link !
                                  I'll try to do some more troubleshooting
                                  • jetadm123
                                    • 2169
                                    In the link that alexanna provided, post #6, one of the pins on the connector is labeled S_B. I believe this is the standby voltage. It should read approx. 5V. Are you at least reading that?
                                    • alexanna
                                      • Mar 2010
                                      • 1346
                                      I could possibaly be wrong, but i think the pin Micom is the standby voltage?
                                      • zulururu
                                        • Aug 2011
                                        • 43
                                        The input connector labelled Micom is labelled S_B on the output connector of the power supply and yes I have 5.21V on that one
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • Manucsl
                                          QE65Q800TATXXC Samsung TV Issue
                                          by Manucsl
                                          Hello.
                                          My TV is a QE65Q800TATXXC Samsung TV.
                                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                          Any ideas to check would be very appreciated 😊
                                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                          02-19-2025, 07:47 AM
