Acer AL1916W
  • zwahelian
    • Jul 2010
    • 11
    Acer AL1916W
    Hey all,
    I've been lurking around this forum for the last two weeks as I have recently become interested in repairing dead monitors, and after successfully repairing an emachines monitor with bulging caps, my inexperience got the best of me with an Acer AL1916W. I got two from my corporate office, one dead and one working fine. After replacing the smaller caps on the dead monitor's power supply, I still have a dead monitor. The power LED light doesn't light up at all. I swapped PSU's with the good monitor and it works fine, so at least I've narrowed it down to the PSU. The only capacitor I didn't replace was the big 100uF 450v su'scon. When the PSU is plugged in, I get no voltage from the leads of the large cap with my volt meter. Should I replace the large cap or is there something else that would be causing my woes?
    Thank you for any help!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Acer AL1916W
    Originally posted by zwahelian
    Hey all,
    Did you check the fuse? (half hidden by the green wire in the first picture).
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Acer AL1916W
      Members here hate su'scon and you may want to replace this cap. But before you do, try (with power off and unplugged)
      1) test fuse to see if it is open
      2) test rectifier to see if it shorted (it is the black long rectangular thing and should be marked with a D on the PCB)
      --- begin sig file ---
      --- end sig file ---
      • zwahelian
        • Jul 2010
        • 11
        Re: Acer AL1916W
        The fuse is fine, how do I test the rectifier to see if it is shorted?
        • retiredcaps
          • Apr 2010
          • 9271
          Re: Acer AL1916W
          With power off and unplugged.
          1) set your multimeter on ohm
          2) number the rectifier pins 1 to 4
          3) put black on 1, red on 2 - record ohm
          4) put black on 1, red on 3 - record ohm
          5) put black on 1, red on 4 - record ohm
          6) put black on 2, red on 3 - record ohm
          7) put black on 2, red on 4 - record ohm
          8) put black on 3, red on 4 - record ohm
          You should have 6 ohm readings.
          Do same test as above, but with diode setting AND you want to reverse black and red.
          You should have 12 diode readings.
          • zwahelian
            • Jul 2010
            • 11
            Re: Acer AL1916W
            Please bare with me... I am a total noob when it comes to this stuff. The multimeter I'm using has many different settings, and I found the resistance tone setting which should give me a tone when touching the leads of the 2A/250V fuse, right? I think I was using it incorrectly and misread that the fuse was fine. I get no tone at all when touching the ends of the fuse. Should I go ahead and order a replacement from digikey?
            Also, could someone recommend the most appropriate fuse on Digikey's site?
            Will part # F3292-ND or F3297-ND do the trick?
            Thanks again, gaining the experience is invaluable.
            • BullPar
              • Jun 2010
              • 3
              Re: Acer AL1916W
              What kind of meter are you using? Dont use the tone setting that can give you false readings.
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Acer AL1916W
                Agreed. I used the continuity setting and got a false reading on a picofuse. It read 18 ohm and that lead me to believe the fuse was good when in fact it was bad. It depends on the multimeter, but some meters will beep if the measurement is under 30 ohms.
                A good fuse should read 0.3 ohm.
                Post a picture of your multimeter.
                Before you order anything, you should check the bridge rectifier. That may be shorted.
                • zwahelian
                  • Jul 2010
                  • 11
                  Re: Acer AL1916W
                  Here is a picture of my multimeter.
                  • zwahelian
                    • Jul 2010
                    • 11
                    Re: Acer AL1916W
                    Just to clarify, I should check the rectifier with it desoldered from the circuit board?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Re: Acer AL1916W
                      I test the bridge rectifier in circuit.
                      • alexanna
                        • Mar 2010
                        • 1346
                        Re: Acer AL1916W
                        Quick question ,Have we ever determined if the fuse is good?
                        Al.
                        • zwahelian
                          • Jul 2010
                          • 11
                          Re: Acer AL1916W
                          with the multimeter set to 200k ohm:
                          black on 1, red on 2 - infinity
                          black on 1, red on 3 - 1
                          black on 1, red on 4 - infinity
                          black on 2, red on 3 - 1
                          black on 2, red on 4 - 0
                          black on 3, red on 4 - 1
                          red on 1, black on 2 - infinity
                          red on 1, black on 3 - 1
                          red on 1, black on 4 - infinity
                          red on 2, black on 3 - 1
                          red on 2, black on 4 - 0
                          red on 3, black on 4 - 1
                          diode test:
                          black on 1, red on 2 - 1
                          black on 1, red on 4 - 1
                          black on 2, red on 3 - .512
                          red on 1, black on 2 - .477
                          red on 1, black on 3 - .517
                          red on 1, black on 4 - .476
                          red on 3, black on 4 - .511
                          please tell me I did this right.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Re: Acer AL1916W
                            diode test:
                            Please retest the ohm test with your multimeter set on 200 setting (the one just left of the continuity rotary setting). 200k ohm is too high. Pin 2 to 4 will be the interesting one to re-measure.
                            If pin 2 and 4 on the 200ohm test still shows a low reading (like < 2 ohms), you have a probably shorted bridge rectifier. To verify, remove it from the board and retest out of circuit just to be sure. If it is bad, you will need the model number and replace it.
                            • zwahelian
                              • Jul 2010
                              • 11
                              Re: Acer AL1916W
                              with the multimeter set to 200 ohm:
                              black on 2, red on 4 - .4
                              red on 1, black on 2 - 1
                              red on 1, black on 4 - 1
                              red on 2, black on 4 - .4
                              I will remove the rectifier tonight and retest.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Re: Acer AL1916W
                                Just a FYI, for resistance test, you don't need to reverse the probes.
                                Diodes are supposed to allow current to flow only in one direction so that is why you need to test the in both directions. One side should read 0.5 to 0.7 and the other reading should be 0L.
                                This definitely sounds like a shorted bridge rectifier.
                                • mscott03
                                  • Aug 2010
                                  • 16
                                  Re: Acer AL1916W
                                  Hey guys- I've been searching for this info all day and glad I found this place! I started to test my rectifier and noticed my numbers were all over the place.
                                  Does anyone have the specific range that all the contacts need to have between the others?
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Re: Acer AL1916W
                                    If it reads less than 100 ohm, I would suspect a shorted bridge rectifier. To be sure, you need to remove it and test it out of circuit.
                                    If it is above 100 ohms, the bridge rectifier is probably good.
                                    • mscott03
                                      • Aug 2010
                                      • 16
                                      Re: Acer AL1916W
                                      OK, I will work on that tonight. Any suggestion on which one / where to order a new rectifier from?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Re: Acer AL1916W
                                        If you are the USA, try digikey.com. What makes you think that the bridge rectifier is bad in the first place?
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • maralexbar
                                          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                                          by maralexbar
                                          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                                          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                                          If anyone knows how to force the external monitor as primary for Notebooks of those models
                                          11-02-2024, 09:18 AM
                                        • noah95
                                          Dead Acer AL 1916W Monitor
                                          by noah95
                                          Hello everyone, i have an old acer monitor "AL 1916W"
                                          it was totally dead but after i replace some bad caps now the led turns green and red when it's in sleep mode.
                                          but the picture at all no backlight or a dim picture in the LCD.
                                          i just wanted to know how can i test the backlight and the lcd or from where to measure the voltage going to the backlight or the lcd, to know if the problem in the psu or not.
                                          i did test most of the component there if there's a short but they seems fine.
                                          03-25-2022, 03:12 AM
                                        • bripoll
                                          Acer Veriton N4670GT Dead
                                          by bripoll
                                          Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                                          The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                                          It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                                          I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                                          I have programmed it, but it still won't start, it is dead
                                          Before programming...
                                          11-23-2023, 02:56 PM
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
