Aopen AK77 working but...
  • sebrad
    • Nov 2007
    • 2
    Hi, I just bought an Aopen AK77 off Ebay for a good price. As advertised it's working (well I put Duron 600, RAM and GFX in it and posted on the table) but there are six capacitors looking very dodgy.
    Most of the larger ones are "KZE" brand and they all look fine, however all six of the Lelon ones look bad, all have bulging tops, four with residue on top and the other two have blown the plugs out the bottom and residue over the motherboard! The best bit is one of them only has one leg soldered to the board, the other is bent under the cap!!! How can it have failed when not electrically connected, unless the "folded" leg is making connection some how???
    How does the board still work!?!? [can take/ host pics if anyone wants to see]
    There are two 1200uF, 6.3V ones, I have some 1500uF 6.3V Rubycon MCZs off another failed board I could use. (They'd be OK wouldn't they?)
    The others Lelons are 3300uF 10v and 10mm diameter. I don't have anything like that and despite quite some searching no idea where to get in the UK. From what I turned up it seams to be a problem, 6.3v not so bad and should be OK, as from what I understand computer volts are 12v (presume not as only 10v rated) and next step down is 5v so 6.3v rated caps should be OK. Not that I can find them in the UK at the moment either.
    I've got some 2200uF, 6.3v Rubycon MBZs off another failed board but I guess they won't do and not keen to try unless likely? (Hardly be worse than the failed/blown/not connected existing ones though)
    On the motherboard I might squeeze 12.5mm diameter caps in but would like to find a source for the 10mm ones as I have a PSU I'd like to repair that also needs 3x 3300uF, 10mm that definitely won't squeeze 12.5mm ones.
    If anyone can point me to some in the UK I'd be very grateful.
    I know TopCat has them but, sadly, as far as I can tell doesn't deal outside US/Canada. Unless some kind soul in the US can order some and then forward to me. (Obviously I'd pay for them and all the postage and a little extra for the effort ;-)
    Thanks, Seb
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Re: Aopen AK77 working but...
    Would you consider with Samxon? If yes, i can ship without any problem.
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
    • Phenos
      • Oct 2006
      • 46
      I recapped quite a few of these boards. I use 4X samxon 3300uF 6V3 for the blown Lelon 3300uF 10V caps and 2X Samxon 1500uF 6V3 or 10V caps for the blown Lelon 1200uF caps. The KZE's should be fine and are from a reputable brand "Chemi-Con"
      These boards seems to be working for a long time with very ugly bloated caps, I had a customer saying that his PC needs to be reset a few times to get it working. The caps where almost completly blown off from the bottom with dried electrolyte stuff tearing over the mossfets.
      • sebrad
        • Nov 2007
        • 2
        Hi, thanks for the responses.
        Phenos: glad to hear the boards can be recapped successfully and that only the 6 need replacing.
        Sound like two on my board, still can't over the one cap that's only connected by one leg and yet the board works!
        Big Pope: from my brief reading of the site, the consensus is that Samxon caps are just fine, that's more that good enough for me! I'll PM you and we can work out the details.
        Many thanks, Seb
        • kahlil88
          AOpen MX36LE-UN which replacement caps?
          by kahlil88
          Just got a computer with this board and ALL of the Lelon RXA caps have failed. Having trouble finding datasheets to match against potential replacements. The caps in question are 7x 1500uf 6.3V 10x20 and 11x 1000uf 6.3V 8x12. Open to replacing with polymers as long as it works.
          10-23-2025, 03:14 PM
        • Topcat
          4700uF 6.3v and 3300uF 16v in a 10mm Diameter
          by Topcat
          Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
          10-14-2020, 06:35 PM
        • MAJACAEM
          AOPEN WT10–FRG chromebook locked
          by MAJACAEM
          Hello fiends
          This chromebook arrive locked with mdm, I try to start SO in devmode but still locked , system message said “Developer mode disabled by owner” system return to normal mode.
          I try steps such as ctrl v …
          04-23-2022, 08:09 AM
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • DS-1
          AOpen i45GMx-I - no power
          by DS-1
          Hi guys!
          I have this minipc with no power. I've found something broken on the board. It's called IRP1207 (or P120T), but I can't find it as replacement.
          I've attached a picture of it.
          Can you please help me to recognize an alternative for it?
          Thanks in advance for the reply!...
          09-07-2020, 12:57 AM
