AOpen i45GMx-I - no power
  • DS-1
    • Jun 2015
    • 82
    • Italy
    Hi guys!
    I have this minipc with no power. I've found something broken on the board. It's called IRP1207 (or P120T), but I can't find it as replacement.
    I've attached a picture of it.
    Can you please help me to recognize an alternative for it?
    Thanks in advance for the reply!
    • 20732
    Re: AOpen i45GMx-I - no power
    International Rectifier IRF8714 .Its a 30V N-channel mosfet,you can replace it with any other that have the same voltage and amperage.Or higher amps.
    https://www.ebay.it/sch/i.html?_from...F8714&_sacat=0
    https://alltransistors.com/mosfet/cr....0087&caps=SO8
    • DS-1
      • Jun 2015
      • 82
      • Italy
      Thanks a lot for the reply!
      Do you think Si4392DY or ME4856 can be used to replace IRF8714?
        • 20732
        The si4392dy max continuous drain current is 1.5A less,and the pulsed drain current is lower on both. I`d replace it with the same part if you can.
        https://cdn.badcaps-static.com/pdfs/...134addc7e3.pdf
        https://training.ti.com/understandin...urrent-ratings
        • DS-1
          • Jun 2015
          • 82
          • Italy
          I've tried with ME4856, but the computer still doesn't turn on. Maybe there's something more broken!
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            by sam_sam_sam
            03-31-2024, 02:12 PM
            09-06-2024, 05:59 AM
