820-00163-A EFI & iCloud Lock Removal
  • hifihifi
    • May 2011
    • 18
    MacBook Pro A1398 (Retina, 15-inch, Mid 2015) 820-00163-A need BIOS dump
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Trying to clear BIOS on 820-00163-A board with EFI and iCloud lock. Dump attached. Can anyone help clear it?
    Thank you!
    • peste
      • Dec 2016
      • 13315
      • ROMANIA
      Re: 820-00163-A EFI & iCloud Lock Removal
      Thank you!
      try..
      • mgrharry
        • Sep 2016
        • 211
        • usa
        That worked, thank you so much! Any guides you can point me to on how to learn the process of editing these BIOS dumps?
        One item of concern though, when I first started setting it up and connected it to the internet after doing a fresh install I got a message about Remote Management saying such and such company "can automatically configure your computer" followed by a prompt to enter corporate credentials. Couldn't get out of that loop until I disabled WiFi, powered off, then power it back on with no internet access. At that point I was able to setup a new account and sign in and reconnect to the internet. But I'm wondering if it will remotely lock?
        This StackExchange thread suggests the possibility of just disabling the MDM daemon:
        https://apple.stackexchange.com/ques...ng-high-sierra
        Thoughts?
        • peste
          • Dec 2016
          • 13315
          • ROMANIA
          Thoughts?
          you can find tutorials in this regard, on the internet.
          • mgrharry
            • Sep 2016
            • 211
            • usa
            For anyone else looking for directions, here's a guide on using hexeditor to remove EFI password: https://gist.github.com/willzhang05/...7ca131e03ca4b2
            • alihomee
              • Dec 2012
              • 1582
              • malaysia
              macbook pro retina 15inch A1398 emc2910
              looking for me clr bios dump for this model ....while reading from board i accidently miss the ori file becoz i was reading with new programer ......mobo code is:820-00163-A
              • peste
                • Dec 2016
                • 13315
                • ROMANIA
                Re: macbook pro retina 15inch A1398 emc2910
                post the serial number S / N on the case ...
                • alihomee
                  • Dec 2012
                  • 1582
                  • malaysia
                  Originally posted by peste
                  post the serial number s / n on the case ...
                  c02qt2pdg8wm
                  • peste
                    • Dec 2016
                    • 13315
                    • ROMANIA
                    c02qt2pdg8wm
                    try..
                    • alihomee
                      • Dec 2012
                      • 1582
                      • malaysia
                      try..
                      thanks for responce ....tried with this file but it turns on all supplies turn on and after few seconds again off
                      • alihomee
                        • Dec 2012
                        • 1582
                        • malaysia
                        notebook was ok and turning on just gor an EFI password i was using a new programer and i missed the ori file
                        • alihomee
                          • Dec 2012
                          • 1582
                          • malaysia
                          any ideas or any other tested file will be appriciated
                          • alihomee
                            • Dec 2012
                            • 1582
                            • malaysia
                            anyone have a working file for this model or any advice on above dump
                            • alihomee
                              • Dec 2012
                              • 1582
                              • malaysia
                              any one here to solve this or any other dump which is working will be helpfull
                              • alihomee
                                • Dec 2012
                                • 1582
                                • malaysia
                                anyone can help i am waitting for so long
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  What is your board number? 820-00163-A?
                                  • alihomee
                                    • Dec 2012
                                    • 1582
                                    • malaysia
                                    exectaly correct
                                    • alihomee
                                      • Dec 2012
                                      • 1582
                                      • malaysia
                                      anyone willing to help
                                      • alihomee
                                        • Dec 2012
                                        • 1582
                                        • malaysia
                                        A1398 emc2910 mobo code:`````````````````````````820-00163-a
                                        while flashing accidently lost ori file ......now tried alot files from fourm but notebook turn on after a while goes off...any one can help....SN:C02QT2PDG8WM
                                        • brock-s
                                          MSI A520M-A Pro with "U-Key" power-on lock removal
                                          by brock-s
                                          I've searched the forums, including review of the "BIOS Guides, Methods, Resources and Tools" section but could not find anything regarding this problem. Additionally, I could not find a thread related to a U-Key lock on an MSI motherboard (or any other brand board for that matter).
                                          I'm working on an MSI A520M-A Pro (aka MS-7C96 ver1.1) motherboard that displays "Warning!!! Please insert USB key press any key to check." upon power-on. This appears to be caused by a setting in the BIOS for "U-Key" being enabled. The owner states they didn't enter the...
                                          09-01-2025, 12:35 PM
                                        • Juan Carlos Medina Franca
                                          Find owner of MacBook air with icloud lock
                                          by Juan Carlos Medina Franca
                                          Is there a way to find out who owns the original email on a macbook air M1 locked with icloud?
                                          06-02-2024, 09:18 AM
                                        • nike486dx
                                          Chinese windows tablet bios lock removal
                                          by nike486dx
                                          Long story short: bought a 8” generic windows tablet (based on Atom x5-z8350, bios chip model is Gigadevice 25LQ64CVIG, uefi vendor is AMI Aptio) for some experiments, and it came with bios lock! I dont have any decent 1.8v programmers at hand nor do i have knowledge in modding uefi firmware, so decided to play safe: dumped the bios with AFU utility, which i attach here. I am hoping to get it unlocked. Also included hwinfo screenshots with general information, the board itself looks generic without any markings.
                                          05-18-2024, 04:27 PM
                                        • lordrussell
                                          a1342 820-2567-A bios lock removal
                                          by lordrussell
                                          Greeting folks...
                                          Well, in true old fart fashion, it seems I have a client who put a boot lock (padlock on the initial boot screen) on his ancient Macbook. I've done the forum search & Google Ranger attack & have found nothing with regard to working/clean bios to redo the job.
                                          The original offloaded bios is attached. Hopefully, one of you code-reading/writing Gods can figure this one out for me.
                                          Thank you so much in advance. I just know there are many of you folks that just love 15 year old tech. (sarcasm, It drives me nuts having to re-learn...
                                          02-06-2023, 09:45 AM
                                        • ArtMov
                                          [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                                          by ArtMov
                                          Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                                          1. I made overclocking lock disabled the default in amibcp
                                          2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                                          03-31-2023, 01:30 PM
