LG 55UF6450 Power Supply Pinout Voltage Question
  • Tjp444
    • Sep 2009
    • 20
    I've been working on this 4K tv, it starts but turns of and off, the logo never comes up. I've done a lot of TV's but this one was a mystery. Seemed like a main board issue, replacing that with one I am 98% sure is good, TV acts the same. I started looking at the power supply and I'm trying to figure out which pins are supposed to be putting out what. I've never seen the attached diagram style before, can anyone assist? I downloaded the service manual but it doesn't show the voltages at the various connectors.
    I'm getting 8v on several pins, just for a fraction of a second the voltmeter reads 13v and then it drops. The voltmeter is good, the ground is good, could this be the PS is dropping under load or am I introducing a measurement error? Thanks for any input.
    Re: LG 55UF6450 Power Supply Pinout Voltage Question
    Left column is for odd number pins:
    Pin 1 = PWR-ON (PS-ON)
    Pin 3 = GND
    Pin 5 = 13.2V
    Pin 7 = 13.2V
    Pin 9 = GND
    Pin 11 = DRV-ON (BL-ON)
    Right column is for EVEN pins
    Pin 2 = P-DIM2
    Pin 4 = 13.2V
    Pin 6 = 13.2v
    Pin 8 = 13.2V
    Pin 10 = GND
    Pin 12 = P-DIM1
    • Tjp444
      • Sep 2009
      • 20
      Thanks a lot Bud, that's a huge help.
      • datas
        • Jul 2016
        • 4
        • italy
        I also have the same problem, on the connector I always have 8v instead of 13v. Have you found a solution?
        • nomoresonys
          • 12330
          • U.S.
          http://www.shopjimmy.com/lg-eay64009...iver-board.htm clear pic.
            Is the PS-ON present when TV's power switch is activated?
            PS-ON <1VDC = TV OFF
            PS-ON >2 ~ 2.5VDC = TV ON.
            • Tjp444
              • Sep 2009
              • 20
              Well, to answer Bud's question, yes, on my TV the on voltage is there all the time, and it has done that with both main boards I have tried. I bought a replacement power supply, the pattern on the screen changed but it still doesn't work (no picture or menu). I swapped the Tcon, that changed the picture (from one dark band down the middle to just blank) but it still doesn't work. It has become my great white whale. Saturday I'm picking up another one that still works but has a cracked screen. Hopefully this will provide me with a supply of parts that I can swap out and figure it out. Saturday I'm picking up another one that still works but has a cracked screen. Hopefully this will provide me with a supply of parts that I can swap out and figure it out. I will post again when I have done that. I don't need the TV it's just become a quest.
              Sorry for any typos I'm writing this from my phone.
              • freakaftr8
                • Oct 2012
                • 3743
                Have you tried the one tcon cable at a time trick?
                • Tjp444
                  • Sep 2009
                  • 20
                  No I haven't, I've never even heard of it. I take it it's self-explanatory? What info should that yield?
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    How many ribbons go from the tcon board to the LCD panel? If only two, disconnect the right side and power up. See if one half of the screen works. If not reverse the process w the other side.
                    • Tjp444
                      • Sep 2009
                      • 20
                      Yes there are 2 going to the panel. Thanks, I'll try it in the morning.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • shamsudeen
                        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                        by shamsudeen
                        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                        i know that in linear power supply the noise will be very low comparing to SMPS supply....
                        07-19-2025, 07:14 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
