LG 47LV5500 - No picture, no back light, no sound, powers on.
  • particlemann
    • Mar 2016
    • 7
    HI all - so I grabbed a non-working LG 47LV5500 from a friend as a project. I am totally new to TV repair...
    So, here are the symptoms:
    The TV has no picture and, as far as I can tell, no sound.
    The unit powers on - i.e. when plugged in, the LED indicator shows red in standby and changes to white when powered on.
    When powered on, the back lights do NOT come one and there is no picture visible with a flashlight. I plugged a laptop into HDMI 1 and 2, and while the laptop recognizes the TV properly, there is no sound. Of course I cannot verify what input the TV is set to, however, I pressed the "input" button on the front enough where it should scroll through either of the HDMI ports.
    Based on reading through this forum and others, it seems like the problem might be with the main board. I have some basic multimeter skills, but where would I start testing? I did look around for a new main board, but they don't seem to easy to come by these days.
    Thanks to all...
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: LG 47LV5500 - No picture, no back light, no sound, powers on.
    We need high resolution pictures of the PSU and main board. Check all DC voltages on P202 connector with TV on and post them with the corresponding pin out name. DRV-ON is your backlight signal.
    You may want to recheck the sound with a DVD player and not the computer.
    • particlemann
      • Mar 2016
      • 7
      Here are the photos...
        I am not sure if this power supply /LED driver board has built-in pull up resistors or, so try disconnecting the cables between the main board and the power supply board and then plug the TV into the outlet to see if you get backlights or not, also check the DCV between the two legs of the main filter caps (those 3 caps laying the side) in the primary side to see if you have close to 400VDC or not.
        • Diah
          • Feb 2013
          • 6599
          your diagnose of main board correct, its mini LVDS, repair cant not, only replace or try chance of 30% to heat ( packing )your main board.
          • particlemann
            • Mar 2016
            • 7
            I disconnected the PSU from the main board. Once done, the power LED no longer turns red when TV is plugged in and on/off toggle seems to have no effect. Backlights did not come on.
            I am not sure which are the main filter caps...
            • particlemann
              • Mar 2016
              • 7
              By "heat packing" do you mean putting the board in the oven at 385F for 10 minutes?
                No, you will not see power indicator because we are trying to do the power supply-LED driver board self test.
                There are 3 black caps laying on their sides right next to each other and close to the AC inlet, so just use the meter to measure DC between the legs of each cap.
                You must be careful since you are working in the primary deadly side of the circuits.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  DONT NOT DO THAT IT WILL DAMGED THE BOARD FURTHER ! Do what Bud says to diagnose it properly.
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    At it again,dumbass? How do you even consider giving a "solution" by looking at a picture? How about a proper diagnoses first? GO AWAY.
                    OP,don't take advise from this dipstick,he's retarded.
                    Proud owner of dozens of broken TV's and many,many,many boards.
                    Our website and passion:http://hollenhundshepherds.com/
                      http://www.shopjimmy.com/catalogsear...?q=LG+47LV5500
                      Is this the exact match of your board based on P/N from SJ?
                      http://www.shopjimmy.com/lg-eay62169...upply-unit.htm
                      LG EAY62169801 (EAX62865401/8) Power Supply 47LV5500 47LV5400 42LW5300
                      Ans also when you have all the cables connected you need to find out if you have >2.5VDC on PWR-ON pin and DRV-ON pin of the connector P201. We want to at least narrow down to see where the problem is first since main board is not cheap.
                      Pictures provided by shopjimmy.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8352
                        Still need those voltages...
                        • particlemann
                          • Mar 2016
                          • 7
                          Sorry for going MIA after you all responded so quickly to me - it's just been one of those busy periods.
                          Anyway, yesterday, out of sheer reckless curiosity, I decided to throw the main board in the oven @385F for 10 minutes and let it cool for an hour. This is an absurd thing to do that has nothing to do with the thorough and methodical methods I came to this board to learn about. But, it worked... I put the main board back in and the TV works fine now - all inputs are working.
                          I have read enough about "reflowing" motherboards etc that I get why it worked, but it still just strikes me as just silly. And, while I am thrilled to have the TV working, I now need a new project where I will actually learn something!
                          Many thanks to all of you for responding to me so quickly and your willingness to help.
                          • thoma
                            • Sep 2012
                            • 268
                            http://alpengeist-tvrepair.blogspot....-clicking.html
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Out of curiosity I put an old board of mine into the oven to see what would happen to the circuit board, 380 deg F for 10 mins and I must admit it did not do the capacitors any good or the scart sockets.
                              The capacitors bulged and the plastic surround of the scart sockets melted.
                              I monitored the oven temp using a thermocouple but the oven was fan assisted if that makes any difference.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Just use a hot air gun and do it, not the shiten/oven method. But glad to hear its fixed but for how long ?
                                • particlemann
                                  • Mar 2016
                                  • 7
                                  Yes - how long indeed!
                                  • Diah
                                    • Feb 2013
                                    • 6599
                                    when it work then will work, unless parts failed. happy you get it working.
                                    when you sitting at sauna you can feel its warm, but when the sauna master start to waved the towel ( like the fan ) all peoples who are sitting there feels their faces burning.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Thats the worst comparison I have ever heard in my life.
                                        dick probably has convection oven which has fan to circulate hot air for even cooking and reducing the hot spot in the oven.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • dronerat
                                          Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                          by dronerat
                                          Hi Guys,
                                          This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                          PSU: L48S6 FHS BN44-00807D
                                          T-Con: BN95-01937A
                                          Panel: CY-GJ048HGLVLH
                                          MB: NA (Currently as the TV is assembled and forgot to take picture)
                                          As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                          It was sent to an authorized service for repairs and returned with the...
                                          05-15-2020, 08:03 AM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
