Dell15 3567 15341-1 bios needed
  • ranjanlaptop
    • Dec 2013
    • 207
    • india
    vegus/turkish skl/kbl
    15341-1
    91N85
    help me please
  • lebana
    • Jan 2015
    • 81
    • sudy
    Re: Dell15 3567 bios needed
    ok
    • kodinabeel
      • Sep 2014
      • 64
      • saudi arabia
      15341-1
      91N85
      help me please
      Please check the attachment
      • electronica
        • Apr 2014
        • 88
        • algeria
        Thqnk you its ok
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Dell inspiron 15-3567 mec1404-nu kbc dump
          Friends, i need kbc dump. Please upload if anyone one of you have it.
          MB: Vegas/Turis Skl/KBL 15341-1
          KBC:MEC1404-NU
          I have 3/5v alw. There is 3v on power switch also but its not even switching. I hace tried CMOS reset and flashing main bios-16mb. Want to try KBC dump.
          • okbalord
            • Jun 2017
            • 205
            • Algeria
            Re: Dell inspiron 15-3567 mec1404-nu kbc dump
            try this bro
            https://www.badcaps.net/forum/showthread.php?t=63381
            OKBALORD
              • 21985
              Heres another bios with clean ME area to try . Sorry no kbc dump.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Thanks for responding. I've tried 16mb dumps from many forums but it doesnt worked. battery charging led also comes on-so its not a failure on very early stage. Thats why i wanted to flash kbc.
                • imranromi
                  • Jan 2015
                  • 1290
                  • Pakistan
                  You have old kbc file?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Imranromi, Have a look at the backup i got from kbc mec1404. It shows 192kb. On internet , i searched alot as well going thruough the datasheet of mec1404-i dont think so there is anything to flash on this kbc(thanks smdflea for pointers to a particular forum). This is what is written in datasheet---
                    MICROCHIP says that in mec1404 there is no FLASH memory.
                    When the signal is removed, the bootloader is started and the code is drawn into the SRAM (RAM)
                    There is nothing to stitch in it. Look for the problem on the spot. Another cartoon can be stupidly removed and dead.
                    Soldering ...
                    1.1 Boot ROM The
                    following is the release of the EC_PROC_RESET # signal, the processor will start executing code in the Boot ROM. The
                    Boot ROM executes the SPI Flash Loader, which downloads User Code from an external SPI
                    . Upon completion, the Boot ROM jumps into the User Code and starts executing.
                    Internal Memory:
                    Boot Rom
                    32kb data optimized Sram
                    Code optimised SRAM options from 96kb to 160kb
                    64bytes battery powered SRAM
                    So i too think there is nothing to flash. Its all about bootloader. I dont know how to fix that.
                    • Sojke
                      • Apr 2017
                      • 131
                      • Serbia
                      Did you check power good signals?
                      • Cashcobra
                        • Jul 2017
                        • 26
                        • GHANA
                        this file is big
                        • emadarion
                          • Jun 2017
                          • 43
                          • Cairo
                          need bios dell Inspiron 15 3567
                            • 21985
                            Re: need bios dell Inspiron 15 3567
                            Post your bios backup and service tag .
                            • ganeshcell
                              • Jan 2014
                              • 80
                              • india
                              backup and try this
                              • razu
                                • Jan 2015
                                • 218
                                • Bangladesh
                                its file size is not accurate
                                • razu
                                  • Jan 2015
                                  • 218
                                  • Bangladesh
                                  Dell Vegas/Turis SKL/KBL 15341-1/91N85 Bios
                                  Hy all friend ....I have this motherboard, (Dell /7th Generation) ddr 4 ram.
                                  Problem : no power
                                  When I plugged in adapter its led glow white color in 2 second....then nothing happens ....all on voltage are present :- switch 3.3v, 3.3v/5v always / 1.0volt/ 1.8volt.
                                  its have 3.3v rtc/rtcrst voltage. no short on coil ...
                                  its not have crystal frequency.....I checked with oscilloscope
                                  I flashed bios from another site then its power on 1 time
                                  I upload original bios.............can any one help me
                                  • peste
                                    • Dec 2016
                                    • 13661
                                    • ROMANIA
                                    Re: Dell Vegas/Turis SKL/KBL 15341-1/91N85 Bios
                                    try..
                                      • 21985
                                      Latest version .
                                      • killersoft
                                        • Apr 2017
                                        • 75
                                        • algeria
                                        Dell inspiron 15-3567 Winbond 25q128svfq
                                        Hello Guys,
                                        I neeed Bios for
                                        Laptop Dell inspiron 15-3567
                                        CPU I7
                                        GRAPHIC Amd Graphic
                                        Motherboard: Vegas/Turis Skl/KBL 15341-1 91N85
                                        Bios: Winbond 25q128svfq
                                        KBC: MEC1404-NU
