Sony LCD KDL 32S3000 standby blinks twice
  • billansor
    • 85
    Hi
    We have this Sony KDL 32S3000 that came into the shop for repairs. It will come up and actually back lights will come on and then shuts down immediately with error code of 2 blinks.
    Error code indicates 12 volt regulation failure. Several suspicious caps were replaced. They were mostly 10 volts and 25 volt caps that were near heat sinks that looked like they were expanding or doming. The values of these caps were still good but one did change in significant value when freezed. These replacements did not do any good other than allow for the tv to stay on a little bit longer.
    I have not been able to get a service manual. I did check some voltages from the power supply board. I measured the 13 volt unregulated supply off of the power supply board and it does come up when the set is turned on and goes up to 15.6 volts and then the set shuts down.
    In reading online, there is information about a Sony diagnostic procedure that will troubleshoot the fault. Does anyone happen to have either the manual and or the troubleshooting diagnostic procedure??
    Also any other ideas on this set would be greatly appreciated..
    Thank you all for your time in reading and any suggestions on how to improve my post..
    Bill
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sony LCD KDL 32S3000 standby blinks twice
    Service manual.
    If you have additional questions about the set, pictures would be a help.
    PlainBill
    • billansor
      • 85
      Thank you for your reply.
      I do not have access to a camera at the moment.. Am working on trying to get one.
      The schematic is not anywhere close to this unit...
      The inverter is on the left side (looking from the opened back), the power supply is next to it.
      The number on the power supply board is APS 229 G1H.
      The new schematic did say that the 2 blink code means that the balancer is not working... What is the balancer in this set??
      Thank you for your time
      Bill
      • Village Electronics
        OldPro
        • 118
        Originally posted by billansor
        Hi
        Bill
        2 blinks is a GH1 board. Remote but possible BU1 board.
        • billansor
          • 85
          Thank you for your reply...
          Is the issue on the GH1 or power board a component failure or cap failure??
          Bill
          • brithepi2k
            Sony KD-65XE8596 no standby light
            by brithepi2k
            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
            cheers...
            09-06-2025, 02:22 PM
          • GoodCapDude
            Sony XBR-75X940E intermittent 6 blinks error code
            by GoodCapDude
            Hi everyone. First post on Badcaps!
            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
            09-20-2025, 06:07 AM
          • Seb932
            LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
            by Seb932
            i'would like to fix my not working LG 49UB850V tv.
            Symptoms:
            -AC plugged in, Standby LED not working
            -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
            Checked already:
            -Powersupply Output in Standby => 3.5V ok
            -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
            Any suggestions what to check next?
            Thanks in advance!
            09-14-2023, 06:28 AM
          • AK_777
            Sony KD-65A1 Repair – 4 Red Blinks Error
            by AK_777
            Hi everyone!
            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
            02-20-2025, 04:15 PM
          • rabbituk
            Sony HCD BX7700dbi CMT flashing standby
            by rabbituk
            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
            02-11-2025, 05:05 PM
