ideapad 3-14ITL6 Laptop - Type 82H7 bios extract
  • yaso143
    • May 2021
    • 51
    • philippines
    can somebody help me extract this bios
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: ideapad 3-14ITL6 Laptop - Type 82H7 bios extract
    DMI 422000 - 423FFF (in 16MB dump)
    Become a Badcaps supporter
    Thanks to all supporters.
    • yaso143
      • May 2021
      • 51
      • philippines
      thanks for this ill reply if this works btw is this a clean bin file? like no dmi info in?
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        Yes it's clean file.
        Yes if it work you have to copy your dmi from old to new , DMI 422000 - 423FFF (in 16MB dump)
        • yaso143
          • May 2021
          • 51
          • philippines
          no luck the laptop still turns on fan spinning icheck all the voltage rails all present i think imight have a dead kbc chip
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            The bios is 200% OK, so either you have some hardware fault, or you didn't program the chip properly.
            • aldopc
              • Jul 2017
              • 484
              • Chilito
              Working 100% test thanks Vesko
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                You're welcome.
                • emhij
                  • Oct 2023
                  • 1
                  • Philippines
                  can you help me too to extract this bios
                  S/N: PF3HZ5RC
                    • 22279
                    Post the laptop serial number
                    There is a bios version GGCN54WW at post #2 or do you specifically want the 55
                    • Melvin Cruz
                      • Jun 2024
                      • 1
                      • Philippines
                      Hi, I tried this bin file to remove bios password and it works! However, touchpad is not working. Touchpad flex or board are not damaged.
                      • adtham
                        • Dec 2024
                        • 5
                        • malaysia
                        Password Lock IdeaPad 3-14ITL6
                        8mb
                        Hello friends kindly assist with password removal, I have tried using hex editor but not successful.
                        S:/N PF2TFVM8
                        post merged..
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12441
                          8mb
                          S:/N PF2TFVM8
                          File's corrupted. Read chip again.
                          • adtham
                            • Dec 2024
                            • 5
                            • malaysia
                            my AsProgrammer detect the chip as W25Q64CV/W25Q64BV/W25Q64FV, but print at my chip is W25R6JV.
                            here is the bin im read by that 3 type
                              • 22279
                              W25R6JV ? ,no such part number, look at it again. Try NeoProgrammer software
                              • adtham
                                • Dec 2024
                                • 5
                                • malaysia
                                here is the pic and bin save by NeoProgrammer
                                • peste
                                  peste commented
                                  Editing a comment
                                  Don't post pictures unless asked to do so...
                              • peste
                                • Dec 2016
                                • 13924
                                • ROMANIA
                                you should have two bios..one of 16MB and one of 8MB, The bios chip must be unsoldered from the board before writing or reading..
                                do not use the clip, you may have errors..if you do not have anything to unsolder it with, solder wires between the programmer and the bios chip..​
                                • adtham
                                  • Dec 2024
                                  • 5
                                  • malaysia
                                  This one?
                                  • byron25
                                    • Jan 2025
                                    • 2
                                    • colombia
                                    Ayuda con esta bios IdeaPad 3-14ITL6: type 82H7 PF3HNY85 necito un extractó o dump de este laptop gracias
                                    Help with this IdeaPad 3-14ITL6 bios: type 82H7 PF3HNY85 I need an extract or dump of this laptop thanks
                                    in English please..
                                    • Md Anowar Hosen
                                      • Oct 2024
                                      • 1
                                      • Oman
                                      4 time blink light onbroad ram problem. after reball ram laptop trun on but no display and i use this bios file laptop was same and disable onbroad ram from bios still laptop auto on and off . i chack all voltage laptop voltage is normal.
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • jendkkd jeje
                                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                        by jendkkd jeje
                                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                        10-11-2024, 03:12 PM
                                      • joven016
                                        Lenovo Ideapad S145 need working bios HELP!!
                                        by joven016
                                        Problem is blinking power led only
                                        i don't know exactly if it's s145-15igm or s145-14igm
                                        have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                        Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                        Already tested some of posted bios here
                                        S145-14igm - success but invalid serial and not booting on OS
                                        S145-15igm - success with serial and some other info in bios but still not booting on OS
                                        already tried installing new windows but always booting on bios setup
                                        windows installer flash drive detected on...
                                        08-21-2025, 10:55 PM
                                      • Fr33man
                                        BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                                        by Fr33man
                                        I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                                        *Novo button power on
                                        *Disconnected internal battery...
                                        09-23-2024, 01:16 PM
                                      • survivalbloke
                                        Unable to extract bios file from Lenovo bios exectuable
                                        by survivalbloke
                                        I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                        Code:
                                        "innoextract 7wcn38ww.exe"
                                        it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                        The trouble I'm having is that I'm not getting the newly...
                                        06-12-2024, 07:55 AM
