A2159 - 820-01598 20V 0.4A no sign of life
  • LeoBolo73
    • Nov 2022
    • 5
    • France
    Hi everyone,
    I'm fairly new to board repair and I'm trying to repair a Macbook Pro A2159 which seems to had some water damage.
    My USB-C Amp meter shows 20V and 0.4A with the motherboard disconnected (it kind of goes up and down from 0.4A to 0.035A after around 30 seconds then back to 0.4A) and 20V and at least 1A (to 2-2.5A) when the motherboard is connected to everything inside the case.
    The CPU heats but that's the only sign of life the mac is showing.
    I use the original 60W charger.
    I tried to figure out a way to find the problem before posting here so I have some values but honestly I'm not sure where to go from now to find the problem...
    I didn't try a DFU as I'm not sure about the problem and didn't want to make more damages without having an idea of the original problem.
    PP3V3_G3H_RTC 3.3V
    PP3V3_G3H 3.3V
    PP1V8_SLPS2R 1.8V
    PP1V1_SLPS2R 1.1V
    PP0V8_SLPS2R 0.8V
    PP0V9 0.9V
    PPVDDCPUSRAM_AWAKE 0.8V
    PP1V1_SLPDDR 1.1V
    PP3V_G3H_RTC 3V
    PP5V_G3S 5V
    PP3V3_G3S 3.3V
    PP1V8_G3S 1.8V
    PP2V5_NAND_SSD0 2.5V
    PP3V3_S5 3.3V
    PPVCC_S0_CPU 0.72V
    PPVCCSA_S0_CPU 0.82V (not stable)
    PPVCCGT_S0_CPU 0.71V
    I found no shorts or stuff like that.
    If any of you would have the patience to help newbie me in the process, I'd really appreciate!
  • oemelectronic
    • Sep 2019
    • 33
    • peru
    Re: A2159 - 820-01598 20V 0.4A no sign of life
    Dfu brother
    • LeoBolo73
      • Nov 2022
      • 5
      • France
      Originally posted by oemelectronic
      Dfu brother
      I tried DFU but it failed with the following message :
      (AMRestoreErrorDomain erreur 9 - Failed to receive message from device, might be connection problem with USB host. (Communication error, possibly USB disconnection)) [AMRestoreErrorDomain – 0x9 (9)]
      Also the only other functionnal mac I have is not with the same OS has the one I want to repair, so I guess it's a problem for the DFU?
      Any one would have another solution to try?
      • mon2
        • Dec 2019
        • 14603
        Test with another known good usb cable. Use as short as possible.
        • LeoBolo73
          • Nov 2022
          • 5
          • France
          I tried with 2 different USB cables (including the original one from the apple charger), I have a third (shorter one) maybe I can retry with.
          • LeoBolo73
            • Nov 2022
            • 5
            • France
            Still didn't work with 3 different USB-C cables.
            May it come from the fact that I don't have the same OS version on both Mac?
            • jason123
              Sony Bravia KD-65X85J No Sign Of life (No BL, Picture, Front LED,..)
              by jason123
              Hi Folks,
              I have a 65" newer (2021 model) that has no sign of life. No backlight, no front LED (assuming it has one) and no audio or turn on chime.
              Photos below of the system
              The CN6401 Connector has the following vitals:
              STBY_3.3V is 3.432 V
              BL_ON low (0.153 V)
              BL_ERR low (0.051V)
              POWER_ON 3.42 V (as soon as I plug it into the wall this comes on)
              REG12V pins 12.7 V
              TCON_VCC12V pins low (0.11V)
              TCON_ON low (0.155)
              Large caps are at 392V as soon as I plug into power
              Seems like a Mainboard...
              09-08-2024, 07:05 PM
            • Francisc Records
              Asus N751JK no power, no sign of life
              by Francisc Records
              First of all im glad i've found this forum and i'm happy to start learning new things and sharing my knowledge with others!
              Long story short : I have a laptop from work that has no power and no signs of life. My first question is: A 90W charger(19V 4.5A) is enough for this laptop? Because the original charger was 19V 6,4A(120W), so all the testing was done with the 90W charger because i don't have a 120W charger.
              This being said, i opened up the laptop and i've inspected the MB and the components, everything seems fine, no sings of explosion, burn,...
              03-27-2025, 01:44 AM
            • alltvrepairs
              JVC lt-32vah3000 no sign of life apart from Digital Audio Laser port is lit RED
              by alltvrepairs
              HI,
              Have this set that does not respond to remote functions. It is either bricked or main faulty as the power supply is on and mainboard supplies seem present. I have noticed the red light from the digital audio out.
              This is an android on a vestel main board 17MB171
              Regards,
              Darren...
              01-31-2025, 09:58 AM
            • pc_okay
              LENOVO LEGION HY660 NM-D562 REV3.0 Power on but no sign of life
              by pc_okay
              I have this board, power button light on only when pressing power button, no fan spinning, nothing else.
              I mesure those signals:
              • ON/OFF# react normaly
              • EC_RSMRST# 1.69V
              • RTC_CLK missing
              • PBTN_OUT# 3V when plug power but stay stuck at 0V after pressing button
              • PM_SLP_S5# PM_SLP_S3# SYSON all missing...
              I have a doubt on the cristal YC1, i see 1.77V on pin 2 and only 0.64v at pin 1 with a dirty oscilation fluctuating between 4 and 25khz
              Cristal YC2 have 0.86V on both pin 1 & 3 with a clean oscilation at 48Mhz.
              Any help please ?
              12-09-2024, 05:26 AM
            • bpjl
              SAMSUNG S22A300N - Dead, no sign of life.
              by bpjl
              I have an old Samsung S22A300N monitor showing no signs of life when plugged in. I'd like to try to run it.
              Motherboard - BN41-01592D (2011.04.19) REV NO: MP 1.0
              As I wrote above - the monitor completely does not respond to the power supply. What I know and may or may not be useful:
              - damaged power socket but it's not a problem if you can buy one
              - power supply rather functional - 14V at the output
              - fuse F801 is OK
              - the 9997GH transistor gets a full 14V on the drain, the gate and the source = 0V...
              09-27-2022, 02:01 AM
