Always turn the power supply switch off
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    On my shop box the shitty case (but one I have to use because it has two easy to insertable physical sata bays on top) for 2.5 and 3.5
    The USB 3.0 case on top is a literal USB extension cable to a 3.0 port on the back (was made many years ago)
    So I got a 5.25 front panel with 4x USB 3.0 ports because the motherboard has 2x 3.0 headers (four ports total). Soo I tried to plug them in and it didn't go. It bent some pins. I was straightening them out with a dental pick when suddenly the computer turned on when I shorted two of the pins. Didn't think much of it and switched the power off
    I took a sewing needle and made the holes on the plugs bigger, it then fit in after
    Aaaand suddenly none of the ports worked after I turned it on. Must have been a power to data short.
    Luckily it has an ASMedia chip for the USB-C and one USB-A 3.0 ports. I was able to get into windows and The USB xhci driver in windows said code 10, failed. Can't get into bios without hooking it to the Asmedia 3.0 port.
    Soooo now I'm going to have to get a PCI-E card with headers and ports (perhaps two) and possibly a hub for the USB-C in the back. God damn that little $17 panel cost me big. But it is my fault. I rarely ever have a non-power header short that causes a turn on. This is actually the second time I've ever had a non power header short turn it on, but the other one was putting a PCI card in and it didn't damage anything
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Always turn the power supply switch off
    I'm thinking two of these
    https://www.amazon.com/Inateck-Expre...dp/B00FPIMJEW/
    • CapLeaker
      Leaking Member
      • 8182
      Funny thing you mention this… had something similar, but on mine the USB was intermittent. So I went and try bending the pins and no go. So I proceeded to change the USB port since the tabs on the sides were broken and the metal casing of the port bent. That was a couple of days ago.
      Look at the main board and see if there is a fuse or something? I had a fuse on the board.
        • 31048
        lol
        in future configure the motherboard to NOT wake on lan,usb,keyboard or any other "event" other than the power button.
        also, if it has a jumper for it, you DONT want usb powered in standby!
        i'v had boards jump to life by accident because of those stupid options - you have to be pretty fucking lazy to need to turn your pc on by touching the keyboard!!!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          WoL is good, saves me a trip to the basement to power up machines to get them to run backups...
          It's a matter of knowing when to turn the switch off or unplugging. Generally if you don't know what you're doing, unplug!
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            Probably several, I doubt I can find the main USB one because none of the ports work
            also with the Code 10, I think it's permanent damage
              • 31048
              usb signaling is 3.3v so look for some tiny zener diodes on the data lines
              • lti
                • May 2011
                • 2548
                At least you didn't swap a motherboard with the power on.
                  • 31048
                  i saw a guy power up a motherboard while it was sitting on the coated-mylar bag once - he thought it was an insulator till it sparked and killed his board! LOL
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Never use an antistatic bag as a insulator, especially for testing.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      Wait, do you mean the grey anti-static bags are conductive?
                        • 31048
                        of course - how do you think they disipate static?
                        it's a thin coating of metal.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          Oh shit. I mean, I've soldered that was on a big static bag, and a few times I've booted boards on a bag. Though without any problems. Hmm, perhaps its not totally conductive
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            I put my meter on a bag and got no conductivity
                              • 31048
                              then it's not anti-static
                              it should read in the megohms
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                oh fuck me. Now it won't reset or power off. Always have to keep the power button down or turn the PSU off.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  https://www.newegg.com/p/N82E16813130979?quicklink=true
                                  well I might just have to get this. Same board, cheaper than getting a new cpu/mb
                                    • 31048
                                    why not see if it's an easy fix first
                                    check if usb signal tracks are shorted to ground or 5v or 3.3v - indicating a blown diode or filter
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      Dude I don't have to skills to replace SMD parts
                                        • 31048
                                        you dont need to, you just remove them - you lose the protection but if it works it's a win
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • shovenose
                                          Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                                          by shovenose
                                          Got this one for free because, well, it no worky.
                                          A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                                          Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                                          08-11-2021, 01:26 PM
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                        • Natob82
                                          Micro Momentary Push Switch?
                                          by Natob82
                                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                          12-21-2022, 05:22 AM
