Hey there folks. Just a quick question here, I really don't know alot about electronics but I was able to at least identify the problem. The missus turned on her pc the other day to hear a loud POP followed by a smell similar to if you had lit a match recently. I checked the usual, fuse/plug/wall outlet and went on to remove the power supply from the pc. It smelled pretty interesting, so feeling confident I'd found the culprit I opened the casing up. Sure enough, there was scorching around a small screwed-on pcb and on it was a burnt cap. Beside it is what looks like a damaged resister which I assume was caused by the heat of the capacitor burning.
Now, at this moment in time I'm buggered for cash. And I'll be honest, having her sitting for hours on my gaming rig scouring Facebook is grinding my nerves.
I've taken apart just about every single bit of 'temporarily disposable' electronic equipment I have and CANNOT find the appropriate 2.2uf 400v capacitor to replace it with. The CLOSEST 400v cap I can find is a 22uf 400v cap (see the image below).
The only 2.2uf caps I can find are 1/8th of the voltage, 50v, and I'm fairly sure that'd be a very very bad idea to use. Would it be safe to attempt to replace the burnt 2.2uf cap with a 22uf cap? Or is that EXTREMELY dangerous? I've taken apart a 30w Marshal amp, no good. Only 50v 2.2uf. A 5.1 speaker system, no good. A 2.1 speaker system, no good. The only thing even CLOSE was a power board from a small DVD player, and that's the 22uf 400v cap I'm talking about. Is there any alternative's I can try or am I buggered to suffer hours of Facebook 'til I can get one of these caps?
Many thanks in advance for even reading this!
Picture 1
Picture 2
Picture 3
Picture 1
Picture 2
Picture 3
