convert a file .axe to Hex to load it in a pic 18f14k22
  • saveriuccio
    • Dec 2017
    • 16
    • italia
    Hello everyone
    I would like to ask you if you can convert a file.axe to Hex to load it in a pic 18f14k22.
    I'll explain better.
    I uploaded a file with .axe extension via an axe027 usb cable on this pic. the cable broke me I only have the pickit2 programmer and it does not load the .axe only Hex format.
    excuse me administrators I do not know if it was the right place to ask such a thing
  • saveriuccio
    • Dec 2017
    • 16
    • italia
    Re: convert a file .axe to Hex to load it in a pic 18f14k22
    there is at least something to read the information. I attach the file
      • 30978
      i think the pickaxe has a bootloader that loads the axe file, so it could be encrypted or incomplete without that bootloader.
      maybe Sonsivri knows more.
      http://www.sonsivri.to/forum/index.php
      • saveriuccio
        • Dec 2017
        • 16
        • italia
        unfortunately the site does not register. thanks for the reply
          • 30978
          the AXE file is not pic code, if you look in a hex editor you see a header and then a block of code that i suspect is tokenised or encrypted.
          • saveriuccio
            • Dec 2017
            • 16
            • italia
            in fact I had imagined it. thanks to all
              • 30978
              why not fix the cable?
              • saveriuccio
                • Dec 2017
                • 16
                • italia
                yes. I took another one
                unfortunately they are expensive
                  • 30978
                  it's a usb to serial board with an ftdi chip and a custom id number
                  i dont think it needs to be ftdi,
                  and a lot of usb 2 serial boards from china for like €2 can either be fixed to show a different id or just patch the id in the software to match a standard cable
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    The TV does not turn on, the standby indicator is on. All voltages are present.
                    Emms is dead. Not readable, not detected.
                    Replaced emmc.
                    But with another dump there is no launch
                    Terminal log
                    UART
                    AC_ON
                    RPMB key is not yet programmed
                    HASH1_VERSION=0x00000000 64bit
                    E-B
                    FDE enabled
                    layout pattern onebin by SAR7,0...
                    06-01-2025, 02:11 AM
                  • Forest79
                    by Forest79
                    However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                    07-23-2023, 07:39 AM
                  • AJ847.63e
                    Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                    by AJ847.63e
                    Hi Folks,
                    Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                    I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                    The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                    05-06-2025, 10:37 PM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                    HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                    This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                    09-06-2024, 11:17 AM
