You can't deny this is not at least a little impressive
^If you have datasheets not listed PM meTags: None -
Re: You can't deny this is not at least a little impressive
Definitely fodder for the ghetto mod thread.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
Impressive.... maybe.
Ingenious - F#$% yeah!
I bet the temperatures are pretty good... well depending if that cooler was mounted directly onto the CPU/GPU or on top of the existing cooler's plate. The later would obviously not be as good... but probably still help a TON.
And I suppose even this is cheaper than building a gaming desktop nowadays.
BTW, I really need to post my computer room's amplifier... if we can call it even that. It's... similar in many ways to what you see above.
by eccerr0rMy cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
by redwireExploding motor cap on Ryobi electric pressure washers.
Recall is for 764,000 units and 16,000 sold in Canada.
"TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
Safety vent too expensive! DELETE DELETE
Channel: General Capacitor Questions & Issues
Hello everyone
I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting... -
by momakaOK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right!
So let’s take...
by sam_sam_samIt weighs in at about 93 pounds very impressive build but it weighs too much to be practical for portability reasons but it can be done very interesting video
https://youtube.com/watch?v=uUVfHaW6..._qzf1JmpTMuEPb01-12-2025, 08:27 AM - Loading...
