suggestions for a cheap but sturdy case
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: suggestions for a cheap but sturdy case
    i got the money; i am ordering it tonight.
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      It came in!
      pictures:
      the front:
      hey- ugly sticker alert!
      look what was underneath the sticker!
      that explains why mine has 2 drive doors, not one and why the dorky dragon logo is on mine but not the originals. fry's discontinued them and sold them to the geeks super cheap. i'd rather it say fry's than the ugly dragon; time to get some goo gone for that residue
      back to your regularly scheduled pictures:
      the front header panel:
      the inside of the case:
      it came with a decent fan (92mm):
      the drive area:
      not a bad case... the metal is a s thick as that of my chieftec and my foxconn. the quality seems good. for $17, not a bad deal, eh?
      sigpic
      • Wizard
        • Mar 2008
        • 2296
        #43
        Not too bad but the tool-less type for drives makes me wary. But case is good.
        I have a decent case and very thick metal 1mm, that uses tool-less drive design except they are rails with pegs to fit into drives and slid into case and make a click-click via metal latches then front plastic is snapped onto case. Very secure. Hard drives are secured via screws. Side panel is tipped into bottom rail via tabs and secured with one screw and one hole tab that plastic panel pegs into at upper area. Nice case through. Need a good mainboard to put in.
        These fans you think are decent are in fact generic, sorry.
        Cheers, Wizard
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          hmm.. i thought jamicon was decent... i have an 80mm out of a bestec, it moves a lot of air for its size, which is good for the 92mm as it was going to be undvervolted via q-fan... whatever... it should be ok since it will not be run full blast all the time.
          better than some of the really bad ones i see...
          as for the tooless drives, they are twist type, with a roll pin to fit in the drive screw hole.
          once i get back to my house in lafayette, i will put the guts into it:
          asus a8n32-sli
          athlon x2 3800+
          evga nforce 7600gt (the ones TC got off ebay for polymodding)
          4gb ddr 3200
          250gb maxtor maxline 5 (i think)
          toshiba dvd burner/samsung dvd-rom
          floppy
          dynex internal card reader
          mostly recapped/modded ultra V 500w
          sigpic
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Jamicon aren't off brand. They aren't Sanyo Denki, but they aren't off brand. I would say on par with Yate Loon/Ong Hua.
              • 31201
              the only bad thing is the damned hole in the front for a floppy.
              unfortunately a common problem that afflicts several of my cases too.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                i was going to install a floppy anyway. the other bay is for the card reader. no problem.
                sigpic
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  a computer without a floppy drive is worthless
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5037
                    • New Zealand
                    #49
                    Yeah, how do people without floppy drives live?
                    Nice case, and the fan is fine, use it until it wears out I say. If it becomes noisy you can probably extend the life by putting some more grease in it.
                    Only thing I can complain about (and this is common with a LOT of cases) is that the rear fan holes are useless.
                    If you want actual airflow, cut the whole thing out with a nibbling tool\hacksaw\can opener and replace it with a chrome wire fan guard
                    -David VanHorn
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      i may dremel out the metal part of the vent, the plastic is about perfect. there is no way of mounting a wire guard there... the back is uneven... but for now i will not mess with it.
                      sigpic
                        • 31201
                        if it's an AMIGA!
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Nice. Other than two main problems
                          1. the uneven back which prevents you replacing the grill
                          2. Screwless mounting on the drive bays. the only cases I've ever seen where thew screwless mounting actually works are CoolerMaster Centurion 5s
                          I think Jamicon fans are good. I've pulled a couple from ageing PCs and PSUs which are still running.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            my plan will be an eventual dremel mod, as there are 2 vents over the fan; a metal one and a plastic one. i will dremel out the metal one as the plastic one is good. the metal is too thick. the reason i don't do it immediately is my parents might not like me working on it as i just bought it.
                            sigpic
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              it actually works pretty well on my NZXT Beta.
                              Plus it's combo mounting. means you can either use the screwless clips or use the 4 screws..
                              that way it also doesn't matter if you lose the clips over time..
                              • weirdlookinguy
                                • Sep 2007
                                • 1638
                                #55
                                You know, that case doesn't look half bad. I don't know why, but... I kinda like it
                                I remember Fry's sold computers in those cases way back in the day when Fry's still sold branded machines.
                                I've found a few old Jamicons still spinning along after several years of service in old PSUs. I'd say leave it, it should be a decent fan.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  i was also thinking that... i bet fry's sold geeks.com those cases when they went out of the pre-fab computer business. it explains why mine is different that than the the others i have seen elsewhere (two cd drive doors instead of one, mainly)...
                                  hey, $17 plus shipping, probably the best case for that price... i remember that the flimsy cases actually cost MORE at the geeks... odd...
                                  sigpic
                                  • bgavin
                                    • Jan 2007
                                    • 1355
                                    #57
                                    Last week I bought an Antec P183 at Fry's for a client. Paid $139.
                                    Today, they are $89.
                                    At least she is paying the bill..
                                    Good luck with the case. I hope it works out..
                                    I gave up on cheap cases because they are to fiddly for me.
                                    Time = Money, and I want something that is easy to use and works well.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      she's been re-boxed; monday afternoon it goes up to my house in Lafayette so i can give it some guts. since it will be in the back of an S10, it needs protection...
                                      sigpic
                                      • weirdlookinguy
                                        • Sep 2007
                                        • 1638
                                        #59
                                        Completely off topic but S10's are legit, what year is yours? Good luck with your move.
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          specs:
                                          1997 Chevy s10
                                          2wd
                                          long bed ('97 was the last year they offered it)
                                          sky blue
                                          normal cab, seats 3 (midgets... the middle seat has NO room)
                                          tilt wheel, stock radio w/tape deck
                                          auto tranny
                                          v6 vortec
                                          a little over 200k on the odometer
                                          it has a bit of a story... we bought it off ebay in new jersey; my mom needed both a newer truck AND a reason to go to jersey; she loves the beach and has friends out there. it was the summer between my 4th and 5th grade ('03)... we bought it, we paid $2700, the kbb at the time said it was worth $4800... only issue with it was some thief cut the spare tire winch to stel the tire, we never have fixed it :/
                                          around 4 years ago, some fucktard in a lexus came rolling around the corner; he was looking for his dropped cell phone instead of looking ahead; we were stuck behind a slow semi (i was taking a pet rat to the vet), he didn't see us, wham bam, his car's totaled, we need a new bumper + 2 brackets... insurance covered it, he learned an expensive lesson.
                                          it does us well, last month it lugged a washer/dryer in one load (2hr down US 421/SR43 and 3 hr down I65 the next day); a fridge in another (same trip as ^'s second day)...
                                          sigpic
                                            ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 10:50 PM
                                            ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 11:05 AM
                                            ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                            This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                            This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 07:07 AM
