Re: Good Fan Brands
I believe JMC datech are just rebranded NMB.
Good Fan Brands
Re: Good Fan Brands
The Sunon maglev fans seem to last forever. Their other fans not so much, but they're hardly the worst out there. I see quite a few noisy Sunons in older Dell PSUs.
Re: Good Fan Brands
i don't know whats a good brand but i can tell you apevia sucks. oh and yes i like sunon, ive seen them in many laptops and they seem to last along time.
Re: Good Fan Brands
Nidec should be moved to OK list. They're not as good as they used to be.
Re: Good Fan Brands
Originally posted by kc8adu View Posti relube any i have in use and they seem to go on forever.many are dry inside.
On the topic of good fan brands, I think Sunon are also an excellent choice. Most of them seem very quiet for the amount of air they move. Delta are good too and very reliable, but they tend to be noisy.Last edited by momaka; 11-01-2010, 10:04 PM.
Re: Good Fan Brands
Originally posted by momaka View PostI found a seized Superred fan in a Macron PSU once. My overall impressions of it were not so good. Instead of having a normal rubber plug like most other fans, it had a plastic insert/plug pressed into the casing. Had to resort to drilling and let's just say it didn't look all that pretty afterwards. It worked though!Fan is lubed and running all good now.
Power Logic is pretty decent. I've had one last 7 years @ pretty much full blast (10-11v) in a L&C PSU. Still works great. When I opened it, there was still plenty of oil in there and the sleeve had almost no play/wobble. Found another Power Logic in a Deer PSU too. Same decent quality.
Interesting. Where do you get this info anyways.
On a related note, I wonder if all of these sleeve bearing fans seize up do to improper (or rather lack of) lubrication at the factory.
Re: Good Fan Brands
Originally posted by momaka View PostInteresting. Where do you get this info anyways.
Another cheap fan brand, Rulian Science and Technology.
Re: Good Fan Brands
the brand i consistantly see bad is xinrulian.
replaced a ton of them in early emachines and recently in vector/black&decker/power on board battery chargers.
Re: Good Fan Brands
Originally posted by 370forlife View PostProtechnic are about the same IMO. Same with Power Logic. Also put Colorful Industrial in this category.
Originally posted by 370forlife View PostYou know how they are always found in sunpro power supplies? Thats because Te Bao is the name of the sunpro factory, Te Bao metallic plastic fans are made by sunpro.
Re: Good Fan Brands
NMB
Nonoise (uses different makers but they tend to be much low current fan for quiietness).
Delta
Nidec
Sankyo
A decent ball bearing fans listed above lasts long time and quiet. Under-volt them enough. 5V-6V is plenty for 12V fans.
Cheers, Wizard
Re: Good Fan Brands
I see top motor a lot in cheaper power supplies like topower and the older antec CWT units. Makes me thing they might just be OK fans.
Globe Fan is a pretty good company.
Te Bao Metallic Plastic seem cheap, and they like to cease up. They can actually be quiet though and push decent air. You know how they are always found in sunpro power supplies? Thats because Te Bao is the name of the sunpro factory, Te Bao metallic plastic fans are made by sunpro.
Cherry brand fans are found in a lot of cheap yuelin made cases and power supplies, they are noisy and don't push much air. Superfan are found in some of the nicer sunpro made power supplies and cases, but they are questionable as I haven't seen too many of them around.Last edited by 370forlife; 10-29-2010, 06:38 PM.
Re: Good Fan Brands
Tly i see fsp using adda fans. Lots of deltas are noisy imo. Antec top motor fans are nois but reliable. (afaik)
Re: Good Fan Brands
There is so many brands making brushless motors and fans in China...
Re: Good Fan Brands
Has anyone herad of Top motor fans? I used a couple on my modded CPU cooler (https://www.badcaps.net/forum/showthread.php?t=11562). Also, what about Protechnic? I've seen a few FSP PSUs with them.
Re: Good Fan Brands
Originally posted by c_heggeGood Brands:
- Minebea/NMB
- Delta
I have a screaming Delta on my Barton system now.
Re: Good Fan Brands
Originally posted by 370forlife...Superred is hard to find, but pretty good... Jamicon are actually pretty decent too.
Re: Good Fan Brands
any opinions on Akasa ?
got some of them with the NZXT Beta case i bought used.
not the quietest but ok..
Re: Good Fan Brands
reliability is simple,
ball-race bearings will slowly get noisy but always run,
bronze or ceramic sleeves will bind or even disintegrate causing the blades to seize - often without warning.
so the bearings are what matters.
now if your asking about db & cfm we can start praising and diss'ing different makes!
