Real Panasonic FJ 1000uF 6.3V Capacitor?
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Hi peeeps and gurus...
    Recently I had brought a small quantity of Panasonic FJ Capacitors.
    I need your guys valuable experiences to distinguish if it is a genuine made capacitor. Many Thanks In Advance!!!
  • yyonline
    • Jul 2009
    • 692
    Re: Real Panasonic FJ 1000uF 6.3V Capacitor?
    It's hard to say for sure without knowing the source, but I don't see anything that suggests these are fakes. They have the "T" vent, rubber plug matches what I've seen for 8mm diameter Panasonic. Font matches what I've seen on other FJs on motherboards.
    • yanz
      • Nov 2004
      • 910
      it looks like nothing is wrong. here i have lots of 1500/6.2 FJ that has the same appeareance like yours. i use them a lot, so far so good. of course i choose my source carefully..
      days are so short when you actually do something..
      • mockingbird
        • Dec 2008
        • 5484
        They look like fakes to me. The printing on the sleeves is poor, and notice how the internal part of the leads are protruding a little bit from the bunge (Like what happens when you pull on a lead too hard).
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          They look like the real deal to me.
          Mann-Made Global Warming.
          - Dr Seuss
          • c_hegge
            • Sep 2009
            • 5219
            I have about 50 820uF 6.3v Panny FJ series which I have pulled off fairly new ASUS motherboards. They look identical to these. The printing on the sleeves looks the same, the rubber seal is the same. I believe that these caps are genuine.
            • mockingbird
              • Dec 2008
              • 5484
              It's funny you mentioned this...
              I had to RMA an Asus P5GC-MX not too long ago. It had all Panasonic caps but it had stability issues as well as power issues and I wondered if Asus had gipped me with fake Pannys. They did look genuine though, not like the ones that were posted here.
              I can't test the replacement they sent me, because I have no LGA775 CPUs, but the one thing I did notice on this perhaps later revision specimen of the same model was that the itty bitty caps on it were now also pannys as opposed to OSTs or Teapos (Can't remember which) on the one I RMA'd.
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • anty
                Lenovo Yoga 13 mb: Yoga 13 MB Panasonic capacitor identification
                by anty
                Panasonic capacitor identification...
                07-07-2023, 01:06 AM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
