mobo power consumption?
    • 31154
    does anybody know how much current on the 12v line an average 64bit athlon or p4 uses?
    not dual-core - just 1st gen stuff like socket 939 or older.
  • Wizard
    • Mar 2008
    • 2296
    Re: mobo power consumption?
    Highest watts is about 68W-80W for most of P4 (especially 2.4-3.2GHz prescott. Buy Northwood if you must for P4's) and around 90W-130W for top of the line EE P4s. Athlon and 939 were 55W to 95W, some just 110W.
    This is why I am scathing of P4 prescott core CPU. Inefficient for wattage used.
    This where I waited around till C2D got affordable enough few years ago and switched from Athlon 462 3000+ barton.
    Linky:
    http://mysite.verizon.net/pchardwarelinks/elec.htm
    Cheers, Wizard
    • sofTest
      • Aug 2008
      • 361
      Often in the 10-12A range for a system. I like this calculator for this kind of calculations.
      Edit: Assuming PSU requirements.
      Be a mensch
        • 31154
        i didnt say "system",
        i'm just wondering about using a small but nice psu for testing mobo's on the bench.
        not up on watt's conversion, how many amps would 100w at 12v be?
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          100w/12v=8 1/3 Amps.
          I would recommend a psu with 15A or more for bench testing p4's so they can handle the sudden power increases that may happen a bit better.
            • 31154
            o.k. that's good.
            i have a dual-redundant unit here.
            DELTA RPS-350B
            +5v 32A
            +5v stb 2A
            +3.3v 28A
            +12v 12A
            total 350w, with 195w of that on the 5v & 3.3v lines.
            *but* it can run at 180%+ of that if i want to max both modules & lose the redundancy.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Joe24
              2070 Super with crazy power consumption numbers
              by Joe24
              Have a Gigabyte 2070 Super with some bonkers power draw readings. Card runs fine, other than some GPU throttling because of the power numbers. But GPU power always reads too high, more than the power reading for the entire card. And VRAM power always reads way too low, along with PCIe and 6-pin power readings. The 8-pin reading seems plausible.
              Typical readout while running 720p Furmark, 8x AA:
              GPU clock: 1590 MHz
              Mem clock: 1750 MHz
              GPU temp: 58.8 °C
              Hot spot: 71.8 °C
              Fan speed: 33% / 1000 rpm
              Mem used: 454 MB
              GPU load: 97%
              02-03-2023, 02:07 AM
              03-31-2024, 02:12 PM
