dell cpu fan wires
  • mattch
    • Mar 2010
    • 121
    dell cpu fan wires
    Anyone know whats up with dell cpu fan wires?
    i have pc where cpu fan died, its 3pin red, white, black.
    my replacement has 5pin (well 4 wires on 5 pin connector, red, white, blue, black)
    My question is anyone know how to wire this thing up without it running full blast?
    i swapped connectors on the bad cpu fan so i dont have to do any splicing, but not sure what to do with white or blue wire.
    when i use white wire it runs full blast when i use blue wire it runs full blast. .
    when i connect blue and white wire to last pin it slows down but still sounds like hair dryer...
  • mattch
    • Mar 2010
    • 121
    Re: dell cpu fan wires
    i think i found answer, not the one i was looking for
    red
    black
    white - rpm
    blue - pmw
    i guess that means since my dell mobo doesnt have that 4th pin there is no PMW so the PMW fan will run full speed..
    i wonder how intel does it, seems like no problem using a 4pin cpufan on 3pin header
    • washu
      • Jul 2009
      • 310
      A lot of Dell 3 wire fans are temp controlled. The fan itself has a sensor which changes the RPM depending on the temperature. Anything else will run full speed because the MB doesn't vary the voltage at all.
      You can try using a big fan and run it at a lower voltage. Your PWM fan is not a good candidate as they don't usually work well at voltages significantly below 12.
      • Wizard
        • Mar 2008
        • 2296
        Dell 3 wire fans is not RPM sensed. It's zero rpm failure detection even it will not set off even the fan is spinning at 100rpm. I have tested and confirmed this behavior. My fix for bog standard 3 wire fans in Dell is make a jumper and jump pin 1 and 3 to prevent alarms and feed 12V from center pin and jumper (it is grounded) and use a fan rpm control to keep rpm under control.
        Cheers, Wizard
        • mattch
          • Mar 2010
          • 121
          Think there is a way to trick the PWM by giving it some power?
          specs:
          PWM Fuction: 2.05A avg, 3.2A peak,
          PWM Signal duty cycle Speed: 0-20% 1000RPM, 100% 5750RPM
          Rated Voltage: DC 12V
          does that mean 12v 3.2A will give me 100% rpm?
          • kikkoman
            • Jul 2007
            • 691
            whoa.
            i know what a fan that draws 2 amps sounds like. is that one of the big Deltas?
            but no, you need a PWM (pulse width modulated) signal to control it. you can either buy a fan controller (i suppose the ones that do pwm are not cheap) or you can hack together a simple 555 circuit.
            "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
            • mattch
              • Mar 2010
              • 121
              2.6A - DATECH
              ill check into that 555 circuit, sounds neat
              i read that when the PMW circuit is open it runs full duty
              and when grounded it runs at 0%, so i have running at 0%, i assume is about 1000rpms? im going to monitor the temps and see how it goes.
              • Wizard
                • Mar 2008
                • 2296
                555 timer IC is *excellent* to build a PWM circuit with a potentiometer, and drive a small signal TO-92 NPN with either pull up or pull down resistor on the output for the PWM input of fan itself. Heck, you can change potentiometer for PTC sensor and tune the circuit for minimum rpm at cold temp and limit the rpm for noise at warmest temp.
                Cheers, Wizard
                • Krankshaft
                  • Jan 2007
                  • 2328
                  You can plug a standard fan into the Dell port if you make a conversion harness by clipping the wires close to the old connector and soldering new ones to your new fan.
                  If you don't want to do that they do make easy plug and play conversion harnesses for these boards.
                  Here is the 3 pin converter one for your board this will allow a standard 3 pin fan to connect.
                  http://www.svc.com/25004-4.html
                  Here is the pinout I believe you're looking for for the 5 pin fan.
                  http://pinouts.ru/Motherboard/dell_fan_pinout.shtml
                  • mattch
                    • Mar 2010
                    • 121
                    No need for any connector rigging, both new and old fan are dells, so same connector, i could just remove wire from old one and place on new one.
                    Of course thats the right way, i did it the fast no patients way, i just rip off the plast connector on MB so now i can do what ever i want
                    I didnt know they made adaptors, good to know for certain things.
                    Still my main problem was the forth wire, the blue one, the pmw one, they dont make a 4pin to 3pin adaptor. Nor would such work sence the MOBO doesnt have anythign for that, i would need a controllor.
                    After i got the fan to slow down i got that "Alert previous Cover" crap, not sure why since i still had white wire in place for zero rpm fan detection, anyway a small wire to jump that white wire to ground fixes that annoying error.
                    So with blue grounded to case, white and black jumped, the new 4-pin PMW fan is doing its job well and quietly.
                    I ran IntelBurnTest and it passed, so for what its being used for im haappy with it.
                    I appreciate all the input from everyone! for you for me
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      Yeah those fans don't get controlled by the PWM on the mobo I remember reading that they have a thermistor in the fan hub that regulates their speed. Also make sure that the fan blows out the back and not into the case. If it blows in flip it around.
                      A stupid poorly designed Dell cooling scheme that they'd defend to the grave. "Aggressive cooling system" my ass.
                      Sure suck in hot air from the PSU fan right above the case fan then blow it over the CPU then blow that same superheated air (from both the PSU and CPU heatsink) across all the other components and out the front.
                      Not to mention where does the PSU fan draw it's air from again? Exactly from INSIDE the case!
                      • yyonline
                        • Jul 2009
                        • 692
                        I've seen a few Dimension 4700s with the 92mm rear fan blowing in... They idled at over 60 celsius, had blown Rubycons and KZJ. The sheet metal of the case was actually warm to the touch. I recapped, flipped the fan around, and the temperatures dropped significantly.
                        I've also seen 4700s with the fan blowing out, which leads me to think that Dell corrected this at some point.
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          The fan was probably flipped by the user I read on their knowledge base that they recommend NOT to flip the fan and it was manufactured this way and doing so could cause overheating and damage to the VRM. Quite the opposite in fact .
                          I love companies who stick to their guns even if they're wrong.
                          • mattch
                            • Mar 2010
                            • 121
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • Themi
                              Dell XPS 13 9310 2 amber 4 white memory failure
                              by Themi
                              I have this laptop a dell XPS 13 9310
                              Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
                              I believe this is the spec from using micron tool to decode marking
                              Images of the ram
                              I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
                              Another...
                              11-24-2024, 09:06 AM
                            • Norrecito
                              iPod nano G3 - alternative soldering point for the white battery wire
                              by Norrecito
                              A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
                              The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
                              This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
                              09-07-2024, 03:54 AM
                            • Geeker007
                              9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                              by Geeker007
                              Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                              I am new to electronics repair, so my queries could be naive but I am ready to learn.
                              So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                              01-28-2025, 03:31 PM
                            • hcinne
                              Dell G15 ryzen edition black screen 2 amber 1 white
                              by hcinne
                              I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                              07-23-2024, 07:56 AM
