more gcc code size reduction for AVR
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Well it's time again to upgrade gcc... I started with gcc 4, and went to gcc 7... got a huge bloat increase, but figured -Os seemed to clear up the bloat.
    Now gcc 7 is EOL and went to gcc 10. Code hasn't changed any, makefile didn't change, I got a bit under 2% bloat with just a compiler change, and surprisingly no makefile changes were needed unlike the previous upgrade! For this one regression testing project luckily I had some room to spare but others I don't, and have been running up against the end of the flash memory.
    Of course I can't do -Os -Os, that wouldn't do any good... so anyone find any stuff that would help out size increase? And once again this is an AVR and every byte counts...
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
    LCD LED TV Service Menu Codes
    TCL LED TV Service Menu Code
    LG LED TV Service Menu Code
    10-31-2024, 03:58 AM
  • dragometin
    Hitachi 40HYC42
    by dragometin
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595
    08-08-2024, 05:53 AM
  • Curtissimo
    HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
    by Curtissimo
    Hi everyone.
    I have a HP Elitebook 850 G8.
    Serial: 5CG2324XM0
    ProdID 6L8D5EC#ABA
    It has a Winbond W25Q256JVEN Chip.
    I need to remove BIOS Password.
    I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
    Attached my dump.
    I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
    I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
    What I did:...
    08-26-2025, 04:42 AM
