PC Power Draw?
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
Re: PC Power Draw?
Hey, I love that show. Always nice looking women on it, and a ferrari model that I've actually driven (308GTB)!!
Team : 49813
Join in!!
Team StatsComment
Re: PC Power Draw?
And they got over on poor Magnum every time!
Mix n match:
Have you seen:Originally posted by Thomas Magnum“Remember I told you I didn't like getting egg on my face? Well, right now, I'm wearing a whole omelet.”
http://magnum-mania.com/Lists/Classic_Scenes.html
https://quotecatalog.com/communicator/thomas-magnum/
Work the lock, don't look at the dogs.
And you owe me $50!
"Recycled how?" "Through a cow.""pokemon go... to hell!"
EOL it...
Re: PC Power Draw?
That brought back some great memories!
Team : 49813
Join in!!
Team StatsComment
Re: PC Power Draw?
That is an APFC power supply according to Supermicro with a power factor of 0.99
So it should measure the same on the old and new meter.
But a good way to make sure the new (and old) meter works as intended is described in this old post:
https://www.badcaps.net/forum/showpo...postcount=2444
Here is the test report and specs of that PSU from what Google provided:
https://cdn.badcaps-static.com/pdfs/...7185a619d9.pdf
https://cdn.badcaps-static.com/pdfs/...87410c7421.pdf"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Re: PC Power Draw?
That's sort of the problem with PVRs and webservers, can't exactly tell when it needs to be on when it's getting "requests" off the air or online... so they need to be up waiting for them
(And even if it's not actively recording, it still needs to pick up EPG data.)
The other thing that pisses me off is that one of the DVBs I have, it goes bonkers when suspended. Driver problem probably, else suspend/resume would have been a good solution, alas foiled...Comment
Re: PC Power Draw?
Thanks, good info. Just for grins, I did order a P3 "Kill-A-Watt" model 4400, which I'll test against the old PM57 power monitor....which should read about the same....back when the PM57 was made, SMPS's weren't the standard; not sure if they had even been invented yet. I'm guessing that meter is circa ~1960's, maybe 1970's. I've had it since the early 90's, came from a defunct shop I bought out.That is an APFC power supply according to Supermicro with a power factor of 0.99
To everyone participating in this thread, good refresher!! I vaguely remember this from my first year in electronics....<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Team : 49813
Join in!!
Team StatsComment
Re: PC Power Draw?
You were lucky to have an APFC PSU and you can compare results. Once you throw in a non PFC PSU you can't. Can't even compare with itself really, you can get a number but it's not meaningful, like if you got 3 when banging on the GPU and 1.5 when you're not, you can't necessarily say that it's double power in the first situation (it could be be more like 2.5x depending on the PF).
Of course this will be moot once you get the Kill-A-Watt which you can do the same as your PM157 and more, including comparing non PFC PSUs.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by nule4hi, im newbee to all of this, but learning. i have problem to locate failed component on motherboard. laptop suddenly stop working, no signs of life at all. try measuring power rails, but as soon i connected before measured multiple power adapters (all of them gave me 19V and working on another laptops), and start measuring first spot on mb (black on ground and red on red wire on mb power connector) it showing power fluctuacting from 0.40V to 0.60V instead 19V. from one ac adapter heard clicking sound, from another ac adapter standby led start blinking. any help would be greatly appreciated. ...
- Loading...
