Heat spreaders on RAM?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8695
    I'm still not DDR4-ized but do memory chips really need heat sinks/spreaders then or now?
    They've never gotten hot except when something's really wrong... There may be localized heating but not much in the chip can change state at any one time so activity is quite low on average.
    Why post? Well I should have added this to the "What Pisses You Off" thread. With the heatspreader on, it makes it that much harder to tell if a module is ECC or buffered, the latter being a huge problem.
    Very odd that adding buffers makes the RAM module cheaper... I guess supply and demand has their ways.
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Re: Heat spreaders on RAM?
    Normally, RAM usually does not require heatsinks. But if you overclock and tend to increase voltages, this produces more heat and heatsunks are helpful. Because of the cpu integrated graphics, most mobos today die either because of caps or lack of heatsinks on their chipsets. I have observed relatively new mobos, where disk conttoller start to work on lower speeds because of lack of heatsink and obvious heating of the chipset, which damages in time. My rule of the thumb is that if I cant keep my finger on it, then it requires heatsink.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      so this would be actually a rule of finger?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8695
        My DDR3 has heatspreaders on them, but thought they were for decoration/product differentiation because they didn't have fins and I've seen many modules without heatspreaders. One would think if it was necessary for one, it should be necessary for more than just one...
        Didn't remove the heatspreader on my modules. Can't remove someone else's heatspreader in a photograph.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          this issue has been discussed before on the wayback machine way before from 2002 when they started having overclocking ram. the general trend around review websites was that they were just gimmicky and some heatspreaders even made the modules run hotter than bare because it obstructed airflow around and across the ram chips.
          ocz also said that was why they came up with their xtc heatspreader design with honey comb grills. this permits airflow around and across the ram chips so they actually run cooler. some reviewers tested this using temperature probes and they agreed with ocz's statement as true and truthful.
          some overclocking enthusiasts even ripped off the opaque heatspreaders off their modules for better overclocking since it ran cooler without them. lol! remember, the ram heatspreaders made the modules run hotter because they obstructed airflow across and around the ram chips.
          so yes, the heatspreaders are just for gimmicks, decoration, aesthetics and telling apart overclocking ram from normal standard value ram.
          Last edited by ChaosLegionnaire; 04-05-2021, 09:14 PM. Reason: grammatical errors fixed.
            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
            Securing a good thermal interface between...
            10-07-2024, 04:35 AM
          • harp
            detecting heat with IR LED receiver
            by harp
            I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
            So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
            Something like termal camera, but in one spot, any simple circuit?...
            09-06-2023, 06:03 PM
          • ludovik
            Moto G84 short after heat
            by ludovik
            i was reballing the power manger of a moto g84, after applying heat i tried to power on and it wouldn’t.
            i injected 1.5v to some capacitor that seem in short because both side beep if tested.
            when i inject i feel the cpu burning;
            since the cpu is exactly on the other side of the board, is that possible that the heat from the reballing damaged the cpu? do you know where i can find schematics or what can i do?
            i know this is not enough to explain the situation so if you need any other info ask me please!
            Thank you very much in advance
            11-08-2024, 02:13 PM
          • jm1234
            Solder joints on heat sinks matter?
            by jm1234
            solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
            I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
            04-28-2024, 04:38 AM
          • myth77
            direct heat stencil,where do you get it? and how to prevent warping?
            by myth77
            So, lately i found that for smaller chips like pch it is very difficult to reball with nondirect heat stencil. So i decided to try direct heat stencils...and while i am waithing some stencils to arrive i have a few questions:
            1. From who do you buy a quality direct heat stencils? i am reading that they can vary in quality and make a big difference...Any trusted sellers?
            2. I am reading also the problem of warping (curving) direct heat stencils...Is it because of quality of the stencils? or/and because some preheating is also required? and help and advice here?
            01-17-2022, 05:06 AM
