I have an HP Pavilion a1140n here that needs some new caps and a power supply, but i am not 100% sure about how i should connect the power supply. The original power supply was a 20 pin connector with the additional 4 pin by the processor. It does work like that but where i am not sure about is the motherboard. It has a 24pin connector plus an additional 4 pin by the processor. Has anyone run into this before and should I or would it hurt anything to connect the 24 pin connector plus the additional 4 pin connector or just the 24 pin or leave it the way it was.. 20 pin plus the other 4pin connector?
sorry if this sounds like a stupid question.. usually i plug a 24 pin connector into a 24 pin slot and i am thinking that the extra 2 pins on the 24pin slot just give a little more stability and power to everything but do not want to blow anything either. and made me take a second thought about plugging it in when straight from HP, they did not put a 24 pin plug on it, just a 20..
